Battery 3rd gen question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, Jun 19, 2024.
  1. Jun 19, 2024 at 11:40 AM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    So I purchased a LI24FM Duracell Ultra Gold Flooded 725CCA BCI Group 24F Car and Truck Battery from batteries plus a little bit over 1 year ago . I am running a 300w amp off of it that’s powering my sub . The battery starting going bad just a little over. 1 year . My concern is that I might have an alternator issue or do u guys think it’s from the amplifier and the cheap battery . I got it replaced under warranty but if it happens again any recommendations? And the bracket in the middle that holds it had some battery corrosion on it ..
  2. Jun 19, 2024 at 11:45 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    That’s a good battery I’ve had 2. Do you play your music with the engine off a lot, running the battery down?
  3. Jun 19, 2024 at 11:49 AM
    Mallcrawler20
    Nope always with the truck running .one thing I forgot to mention was there was some battery corrosion build up on the bracket in the middle of it wonder maybe it was leaking ?
    davidstacoma[QUOTED] likes this.
