Battery booster pack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bagster, Feb 16, 2013.
  1. Feb 16, 2013 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    AND.....if using it thru the cig lighter, or whatever, it wont deliver more than 5 amps.
  2. Feb 16, 2013 at 6:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I used it at the battery
  3. Feb 16, 2013 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    so you got a 100 amp boost on a weak battery. It beats getting a jump start.......barley.
  4. Feb 16, 2013 at 6:05 PM
    OZ-T
    Peter North
    British Columbia
    Like I said , worked great both times
  5. Feb 16, 2013 at 6:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cheers: I rather have a decent battery, and not have to worry about it at all.
  6. Feb 16, 2013 at 6:07 PM
    OZ-T
    Peter North
    British Columbia
    I was jumping other people and trying to answer the OP's question
  7. Feb 16, 2013 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I really dont need to hear about your homosexual antics.
  8. Feb 16, 2013 at 6:09 PM
    OZ-T
    Peter North
    British Columbia
    Reported
  9. Feb 16, 2013 at 6:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Received, and deleted.
  10. Feb 16, 2013 at 7:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OP as an emergency device they work very well. and it is extra good if it has an inverter as you could use it to charge the cell phone also.
    It is not a substitute for a defective battery.
  11. Feb 16, 2013 at 7:05 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    This. If you feel that your battery might be getting weaker, just replace it. Although having a booster is handy, too.
  12. Feb 16, 2013 at 7:30 PM
    OZ-T
    Peter North
    British Columbia
    OZ agrees with Jimmy's dismissal of Chris' nonsense
  13. Feb 16, 2013 at 9:40 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    +1
  14. Feb 16, 2013 at 9:45 PM
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
  15. Apr 4, 2013 at 3:15 PM
    #35
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
  16. Apr 6, 2013 at 5:57 AM
    #36
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    A tip........
    Most major auto parts and battery dealers will test your battery and charging system for free, but the battery needs to be externally charged before the test to achieve a more accurate measurement of it's health. A healthy battery, charging system and starter are co-dependent on each other. Terminal corrosion is one of the most common causes of starting problems.
  17. Apr 6, 2013 at 7:59 PM
    #37
    DJSPEC
    Sean G
    Kaimuki,Hawaii
    Very true. I test batteries for free at my Firestone.
  18. Apr 7, 2013 at 7:11 PM
    #38
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Nice. I use those for my last job. They are a great brand for just a straight up battery jumper. They worked great for years with weekly use.
    If you ever need a beast of a one that will start anything check out the Truck PAC ES6000. I used to use that one to start an old John Deere 310B. It had two huge 6 volts.
  19. Apr 7, 2013 at 7:13 PM
    #39
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
  20. Apr 7, 2013 at 7:21 PM
    #40
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    easy people, dont get in an uproar over a question!!!! anyways, how much did the oddessey set you back, and what store sells them, sounds like one strong ass battery, and one i will consider in about a year or two for when my battery is 2-3 years old
