Battery cable harness upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ironworker125, Jan 18, 2020.
  1. Jan 18, 2020 at 11:00 AM
    Ironworker125
    Ironworker125 [OP] New Member
    2003 Tacoma 4x4 base
    Where can I find an upgraded battery to starter harness to buy. I have a 2003 Tacoma 2.7 4x4. Thanks
  2. Jan 18, 2020 at 12:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Have some one Make one.
    Just a matter of crimping the correct lugs on heavier cable.
    I use 1/0 welding cable
    Area51Runner likes this.
  3. Jan 18, 2020 at 2:12 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    It’s super easy just to make your own.
    Where do you live? Maybe someone nearby has a crimper that can lend a hand.
    I have a hydraulic one if you happen to be in Northern CA.
  4. Jan 18, 2020 at 2:51 PM
    Ironworker125
    I live in Texas. Just put another motor in and new starter. Starter will not engage. Battery terminals are bad, I’ll try new ones to see if that helps.
  5. Jan 18, 2020 at 2:54 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I know @Mr.PowerTrays makes them
  6. Jan 18, 2020 at 2:55 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Welcome to TW!
    As the other two mentioned, really straight forward making your own however if you'd rather just order something, take a look at this thread - specifically, 2nd post.
    https://www.tacomaworld.com/threads/big-3-wire-upgrade-question.488281/
    I've used CEAutoElectricSupply before and they are top notch. If you have direct questions about their offerings, reach out to them.
    :thumbsup:
  7. Jan 18, 2020 at 3:01 PM
    Ironworker125
    Thank you
  8. Jan 18, 2020 at 3:10 PM
    Area51Runner
  9. Jan 19, 2020 at 8:45 AM
    1997tacomav6
    Denver
    Napa Auto parts will actually make you one any size and cable gauge, any length.
    I had one made that went from the battery to the alternator for 15.00.
    Both ends crimped and heat wrapped.
    In Denver they do anyway.
  10. Jan 19, 2020 at 10:33 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Glad you cleared up at your store.
    Not sure I trust any I deal with not to have to order the lugs
    1997tacomav6[QUOTED] likes this.
  11. Jan 19, 2020 at 11:30 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    You just replaced the engine and starter and you're suspecting the problem is the cables? Hmm...
