Battery cable question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, May 19, 2025.
  1. May 22, 2025 at 9:42 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Heat and grease is enemy of plastic wire insulation......its really a no brainer
    much easier/cheaper to replace loom or tape.....instead of splicing new wires
    especially on the header side
    Suspect most crank sensors dont fail at the sensor.......think the pigtail degrades and starts causing intermittent problems....no starts
  2. May 28, 2025 at 10:49 AM
    rluis05
    rluis05 Active Member
    99 Tacoma SR5 3.4
  3. May 29, 2025 at 12:06 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Ha-ha! Wow! All the great advice. I got totally sidetracked by something shiny & am finally getting back to this…. Thank you to all….
  4. Jul 2, 2025 at 9:31 PM
    Tripodchief
    Tripodchief Well-Known Member
    Cb
    2003 tacoma 2.7 regular cab 5 speed 4x4
    None yet
    I had just bought a new battery for the Durango then blew the motor the next week. It was a lot bigger and the posts were on the wrong side, but it worked out and i fit it in the taco,I think it's like 1000cc amps, little over kill
    Kristi with a K[OP] likes this.
