Battery cage needed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by R0dzilla75, Sep 26, 2015.
  1. Sep 26, 2015 at 8:30 AM
    R0dzilla75
    R0dzilla75 [OP] Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I'm putting this out there to see if anyone knows, or can fabricate a decent battery cage/tie down that will work on a 27f interstate sized battery. Put a call in to pellfreybilt because I saw he makes on for the series 31 diehard but that won't fit. Not much to choose in the wold of aftermarket parts. Long story short my battery came loose and one of the tops that contains the water came off and was lost. It's a design flaw. I need a better solution. My ears are open
  2. Sep 26, 2015 at 10:21 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Not sure what the tray and the down look like on a 05 but it should be pretty simple. A properly sized tray can be had for cheap at most auto and marine parts stores. Same with threaded J-hooks and they can be bent to shape if necessary. Top straps in any configuration can be made out of mild steel, stainless, or aluminum with nothing more than a vise, hammer, and a drill motor. A rough but serviceable job can be done with nothing but two pair of pliers and a drill.
