Battery connection (posts) outside the engine compartment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LTG4087, Feb 28, 2019.
  1. Feb 28, 2019 at 5:07 PM
    LTG4087
    LTG4087 [OP] Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I'm going to be adding a portable air compressor which I plan on storing behind the back seat. This will be a direct battery hook up to run. Has anyone installed battery connections somewhere else on the truck to facilitate quick hook up without lifting the hood? Thinking maybe in the bed in the cubby or perhaps in a discreet place by the grill.
    Or am I overthinking this... maybe it's not that big of a deal to lift the hood on the not so frequent need for air.
    GSDLVR123 likes this.
  2. Feb 28, 2019 at 5:08 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    its not that big of a deal to lift the hood.
    JoeCOVA and JCOOR like this.
  3. Feb 28, 2019 at 5:59 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Well, does lifting the good bother you that much and are you using the battery that much??
  4. Feb 28, 2019 at 6:02 PM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Creation of a solution to a problem that does not exist.
    Pop the hood and connect the compressor via the clips. The time spent opening the hood will be nil relative to the time it will take your portable air compressor to fill your tires.
    shakerhood likes this.
  5. Feb 28, 2019 at 6:06 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Personally, I wouldn't want that wire energized all the time unless I really needed it to be.... so then you are opening the hood to close a circuit breaker or switch, or installing a relay and remote switch... getting more complicated it seems..
    r1200gs4ok likes this.
  6. Feb 28, 2019 at 7:32 PM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Yeah, I guess it's a bad idea after all. I'll just work with opening the hood which will get a lot easier when I install the Redline Tuning lifters I've got on order. I'm going to get a 115v ac to 12v DC 20A converter for use in the garage so that will cover airing up the truck and wife's car easily, and pop the hood when on the road if needed.
    Thanks for the help.
  7. Feb 28, 2019 at 7:35 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    ian2016 likes this.
