Battery Corrosion on my 2010 Ttacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tdog123, Feb 9, 2014.
  1. Feb 9, 2014 at 7:51 AM
    tdog123
    tdog123 [OP] New Member
    Terry
    Suffolk
    2010 prerunner TRD 4 Dr
    I have 2010 TRD tocoma sport. I have a bad corrosion problem on the pos battery cable. Truck would not start this morning.
    About every 4 months I have to clean the battery cable and terminal.
    Today Sunday February 8th I can see that corrosion has eaten away part of the battery cable copper terminal. I make sure all the connections are tight and I have applied corrosion prevention red compound to all the terminals. What could be causing this problem.
    Thanks for any help
    Terry
  2. Feb 9, 2014 at 7:59 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Clean them good and then spray them with Fluid Film. Works like a charm.
  3. Feb 9, 2014 at 8:06 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Clean and cover with dialectic grease. Autozone sells small packs near register.
  4. Feb 9, 2014 at 8:06 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Get the battery and alternator checked. If it's off gassing that much there could be an issue.
  5. Feb 9, 2014 at 8:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A loose connection can facilitate corrosion on the terminals. Clean the terminals, and make sure the connections are tight.
  6. Feb 9, 2014 at 8:20 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    You need to replace the battery as the factory seal between the battery case and the lead terminal has most likely failed. Also replace any cables or terminals that have been effected and clean all vehicle surfaces with a baking soda water mix prior to installing new battery.
  7. Feb 10, 2014 at 6:13 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    i run ALOT of high current devices and had an extremely bad problem like you are having, a mechanic friend told me to clean very well, then keep a coat of oil or even vasoline on the terminals, works perfectly! no problems since, also make sure your not running the batt so hard it gets hot and the battery acid is bubbling out. check battery fluid level
    cheers,
    disco
  8. Feb 10, 2014 at 9:36 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Had this same issue on my wife's mustang
    Had the battery replaced - warranty
    Unbeknownst to me ... The tech pulled a battery out of a new car in the prep area and put in my wife's car... He must have jerked the cables off because the positive terminal had a crack around the back which was hard to see but I was seeing green acid buildup every few months
    Took the pos cable off one morning for another cleaning and it was rather hot that day and I could see the crack where the vapor was leaking from
    Ended up having to replace the battery and the cable end also because I didn't look in the first place
    Baking soda and water is your friends
  9. Feb 10, 2014 at 9:41 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    I would just clean the hell out of it if not a new battery and then Coat it with a bit if chain oil or something
  10. Feb 11, 2014 at 2:35 AM
    tdog123
    Terry
    Suffolk
    Guys: Thanks for the replys. Had to replace the battery. $100.00 for new battery.
    Thanks again
    Terry
  11. Feb 11, 2014 at 6:16 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    There are a number of things that can cause battery lug and terminal corrosion. For more information on maintaining your battery, see Section 3 in the Car and Deep Cycle Battery FAQ found on www.batteryfaq.org.
