Battery Dead from Lights On for 20-30 Minutes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kremtok, Nov 15, 2017.
  1. Nov 17, 2017 at 3:37 PM
    #61
    Adventure Ready
    Adventure Ready Adventure Ready
    Seattle, WA
    These are a good quality jump battery. There are some crappy ones out there.
    Spare Parts[QUOTED] likes this.
  2. Nov 17, 2017 at 4:03 PM
    #62
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I’ve done the trim and simply found a couple little pieces of plastic that I could grind into a little “L” shape. Then affixed them to the underside of the tray with some epoxy; resulting in two little “extension tabs” sticking up on the trimmed side of the tray to hold the battery on that side. It doesn’t take much to keep it from sliding around, considering the battery is under pressure from above.
    Note: imagine bending a stick of gum into an “L”. One side gets epoxied to the underside of the tray and the other side serves to keep the battery from sliding. You could probably get away with one tab but I liked having tabs by the battery corners (2).
  3. Nov 17, 2017 at 4:07 PM
    #63
    NMTrailRider
    New Mexico
  4. Nov 17, 2017 at 4:08 PM
    #64
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Cool, thanks
  5. Nov 17, 2017 at 4:11 PM
    #65
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    USB to charge, I can charge at home, in the truck or via solar panel. also has USB out to charge phone or what not.
    NMTrailRider[QUOTED] likes this.
  6. Nov 17, 2017 at 4:23 PM
    #66
    Kremtok
    Kremtok [OP] Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Minor update here, folks. First I tested the battery in the garage after the truck had sat all night: 11.9v. Clearly that's not good. Then I took the truck down to O'Reilly and had them test the battery. Turns out there's nothing wrong with it, but as expected the voltage was low. Basically that just means that I don't drive my truck enough to get a good charge on the battery during normal usage.
    Now that I know what the problem is, we can work to avoid it by taking a longer drive at least once a week. I also ordered a charger so that I can manually top off the battery if I don't get a chance to do some driving.
    Thanks again to everyone that has offered feedback and information on my issue!
    Spare Parts likes this.
  7. Nov 17, 2017 at 4:31 PM
    #67
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
