Battery dead question, Need help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nickbean, Oct 1, 2012.
  1. Oct 1, 2012 at 6:26 AM
    nickbean
    nickbean [OP] Active Member
    Nick
    Auburn,AL
    TRD off road 4x4
    265/75/16 coopers, tint. debadged, TSL rear leafs, 5100's set at 1.75, dipped wheels,
    I have a 2010 Tacoma double cab off road 4X4. It has 39,200 miles. I have not left any lights or any other known battery draining devices hooked up in the truck. The battery was acting weak yesterday so I put it on a charger and within 4 mins it was completely charged. I took it off the charger and drove it around for about 15 mins. This morning when I was leaving for work the battery was completely dead. Barely had enough juice to make the starter click. Besides the battery, IS THERE ANYTHING ON THE TRUCK THAT COULD BE CAUSING THIS?? I.E. bad fuse, short, etc.?
    Just curious if anyone else had a similar problem. It seems way too soon to be replacing a battery. 2 years and less than 40,000 miles?!?! My wife's toyota solara was 5 years old with 75000 miles before it needed a battery.
    I'm going to buy a battery at lunch, but I wanted to consult the vast amount of knowledge here first to keep me from chasing my tail.
    Thanks in advance
  2. Oct 1, 2012 at 6:28 AM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    I wouldn't think so. I had a Honda Accord and the battery went dead at 24,000 miles. It just happens sometimes.
  3. Oct 1, 2012 at 6:29 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Not sure but at Lexus they give a warranty on the battery... wonder if Toyota does the same thing. Oh just realized that you are JUST out of warranty.
    Have you done any mods to it?
  4. Oct 1, 2012 at 6:35 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    You live in Alabama where it is very hot in the summer. Heat is another killer of batteries. I lived in Florida for four years. A friend of mine that has lived there for many years said it was good if you got two years out of a battery living here. My battery went bad 3 months after moving there!
  5. Oct 1, 2012 at 6:36 AM
    nickbean
    Nick
    Auburn,AL
    TRD off road 4x4
    No real mods except for cosmetic stuff. No aftermarket stereo. Sylvania silverstar bulbs are the only electrical mod. Yep, just outta warranty..... Guess its time to put a real battery in it. I was just curious. Thanks
  6. Oct 1, 2012 at 6:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you know what? a cheap radio shack multi-meter would tell you just about everything.
    what voltage are you seeing at idle? hmmm. at this point..you dont know if your alt is doing alt-y things.
    i think i paid $40 for mine at Sears..i use it all the time i have a battery question..
    you could be tossing a perfectly good battery.
  7. Oct 1, 2012 at 7:28 AM
    shemp
    shemp Well-Known Member
    A bad voltage regulator (part of the alternator) can fry a battery. By the sounds of it, the battery definitely needs to be replaced (4 mins should NOT completely charge it from drained). Have the alternator tested to make sure it doesn't cook the new one if it happens to be faulty.
  8. Oct 1, 2012 at 10:12 AM
    TX Tacoma
    TX Tacoma Fightin Texas Aggie
    Arlington, TX
    If you have broken plates inside the batttery it can show fully charged with no load, then the volts drop off to near zero when it's loaded. A multitester is the best tool to diagnose your problem.
  9. Oct 1, 2012 at 10:15 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You should have a pro-rated warranty. Take it to the dealership.
  10. Oct 1, 2012 at 10:19 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I've had my 08 for just under 5 years and am on my third battery :notsure: No aftermarket electrical stuff - just stock batteries. Have an Autozone one now.
    The battery in my Camry died @ 4 1/2 years and an Autozone one has been kicking for 8 1/2 years now. Been told for over a year that I need a new one, but this one keeps starting. One day soon....
  11. Oct 1, 2012 at 10:24 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i did not read all the comments. but i got my ’07 may of last year. with 24,9**k on the clock. not long after it started doing the same, replaced battery and it has not done it since. maybe it’s just a bad battery.
  12. Oct 1, 2012 at 10:30 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Be sure your battery terminals are clean, corrosion will act exactly this way. Buy a terminal cleaner and clean them reall good, remove from battery posts to clean inside terminals.
  13. Oct 1, 2012 at 10:36 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    My alternator went out at about 25K miles and had to replace it so test that to before you think its just a battery issue.
  14. Oct 1, 2012 at 12:16 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    After replacing the battery, take it to autozone to have the charging system checked for free. A bad alternator will kill a new battery.
  15. Oct 1, 2012 at 6:43 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    make sure the cells have liquid in them. little on no liquid will do this. Batteries can die at any time. The battery had to be replaced on my brothers 2012 civic.
  16. Oct 2, 2012 at 9:47 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Funny how this thread mentioned an accord and now civic. We have a 2010 civic with a battery that died this past weekend. Only 2 years and 2 months we owned it!
  17. Oct 2, 2012 at 10:14 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Heat kills batteries, repetitive deep discharge cycles kills batteries, not keeping water topped off (sometimes it vents out when it heats up) within the battery also will prematurly kill it. Excessive vibration as well. Quality of the battery mfg may have also had something to do with it.
    It would be worth checking the terminal voltage with a multimeter and see if its in the nominal 12 volt range with the engine off. If its lower than 9 volts, its probably dead. My old mazda eeked out another month or two from a 'dead' battery, but once I let it sit for a week it refused to start.
    If you have a separate donar battery to connect in parallel (don't try jumpstarting it!), you can try getting the truck started and observe whether its charging or not, although you would need to run the truck for a whlie and waste gas. Pull the battery and head to autozone to use their battery tester??
  18. Oct 13, 2012 at 5:15 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    At 80 degrees F, if a 12-volt car battery is below 12.06 VDC, it probably will not have enough performance to start a cold engine and below 11.89 VDC it is discharged. A healthy, fully charged battery will measure at least 12.65 VDC after the surface charge is removed. For more information on testing car batteries, please see Section 4. in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  19. Oct 13, 2012 at 5:45 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My stock battery died at 3 yrs-
  20. Oct 13, 2012 at 5:51 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    My 2007 lasted up until a couple weeks ago. It only has 38,000. But it happened the next day after wifey drove it.:p
