battery died. Jumped it. multiple system malfunctions on display.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soleilchef, Feb 10, 2025.
  1. Feb 10, 2025 at 12:51 PM
    Soleilchef
    Soleilchef [OP] New Member
    2018 toyota tacoma
    I left the radio on all afternoon and the battery died. I jumped it off a battery pack. Immediately after the jump 3 error messages appeared on the dashboard. 1. headlight system malfunction 2. pre collision system malfunction 3. check vehicle stability control system. The truck started, continues to start and drives without problems. The battery is only 18 months old and tested fine. Headlights seem to work fine. Any suggestions?
  2. Feb 10, 2025 at 12:58 PM
    MilkDud
    MilkDud Well-Known Member
    2021 MT DCSB Off-Road
    Could try disconnecting the battery for like 20 minutes, then hook it up and start it. See if the codes clear
    G2.M6 likes this.
  3. Feb 10, 2025 at 1:00 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    This has a 95% chance of success
  4. Feb 10, 2025 at 1:00 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You usually have to reinitialize certain systems when disconnecting/reconnecting the battery. A simple code reader won't do it.
  5. Feb 10, 2025 at 1:02 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Sometimes when a battery is run flat the systems need to re-set by driving for a while. Might only take a few miles. Can't hurt to disconnect for a bit, as suggested above, and even connecting to a charger while disconnected.
  6. Feb 10, 2025 at 1:05 PM
    MilkDud
    Can you expand on this. Hooking up a new battery after a long pause will lead to non-functioning systems? Seems like a bad design for a truck
  7. Feb 10, 2025 at 1:32 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I've had my battery in and out, or disconnected on probably a dozen occasions for varying periods of time.
    Nothing unusual or unexpected happens during a normal battery disconnect or swap.
    All the "systems" boot up as you would expect them to...
    Battery jump starts, however, are a different story, especially if the cables just happened to get reversed...
    https://www.tacomaworld.com/threads/battery-died-jumped-it-now-i-got-error-messages-help.752813/
  8. Feb 10, 2025 at 1:50 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    This is news to me. My truck must be special as I've swapped out the battery twice with zero hiccups.
    OP, do the battery disconnect thing.
    RIX TUX likes this.
  9. Feb 10, 2025 at 2:00 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    That heavy power draw brings the line voltage below minimums for the computer. If your battery is flat and sitting around 9-10volts, jumping is not the best thing to do if you can avoid it. Unplug the ground terminal and run a charger on it first. unless you have a 40amp charger DO NOT try to charge a flat battery with it still connected, the alarm will sound and when you try to disable the alarm by exposing your fob, it will go into ignition mode, the high pressure pump, lights, accessory loads will try to pull power from your charger and potentially destroy it.
  10. Feb 10, 2025 at 2:00 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I work at Lexus. On some models we have to initialize the steering sensor when we have the battery disconnected or multiple warning messages will appear.
    What messages are you seeing?
    I took a quick peek on TIS, looks like no initialization is needed on that vehicle.
    Beerpayzdabillz likes this.
  11. Feb 10, 2025 at 2:03 PM
    canuck guy
    Alberta
    23TRDOR
    Sometimes weird things happen to vehicle electronics when a battery is drained because radio, lights or other things left on vs battery going bad on its own.
  12. Feb 10, 2025 at 2:43 PM
    Soleilchef
    2018 toyota tacoma
    Disconnected battery with same result.
  13. Feb 10, 2025 at 2:49 PM
    Buck Henry
    I wonder if that battery pack caused some fuses to blow? Those things always did make me nervous with the power they store and release when used. Hopefully it didn't do some sort of ECU damage?
  14. Feb 10, 2025 at 2:51 PM
    canuck guy
    Alberta
    23TRDOR
    Try driving for a few miles. Also it might "test fine" and may be only 18 mo old but it could still be no good.
  15. Feb 10, 2025 at 3:28 PM
    vaca
    vaca Well-Known Member
    PA
    2020 SR DCSB 2.7 2WD
    First thing I would do would be to fully charge the battery with a battery charger.
    shakerhood, Chew and Hunter gatherer like this.
  16. Feb 10, 2025 at 3:31 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sounds like over-voltage from the power jump pack- what type was it?
    Chew and Beerpayzdabillz like this.
  17. Feb 10, 2025 at 9:39 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Replace your clock spring. Buy oem is my recommendation- search the online dealers for best price, search for any coupon codes. Install isn’t bad, was my 1st time ever removing a steering wheel- there’s a few videos that will get you where you need to be but might have to look at 2nd gen. Mark your wheel and the spline for reinstall… I’ll have to take mine off again because I’m 1 tooth off
    And that’s why I don’t have the noco in my truck anymore.
  18. Feb 10, 2025 at 9:56 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    try driving it a day or two
  19. Feb 10, 2025 at 11:52 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What others somewhat said. What do you mean battery tested fine? Did you disconnect battery, and put it on charge, before testing it?
    Chew likes this.
