battery died :(
Discussion in 'Technical Chat' started by DanGer, Apr 23, 2009.
  1. Apr 23, 2009 at 6:56 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    So earlier tonight I have my battery tested here are the results:
    Voltage: 12.4 V
    Rated: 582 CCA
    Actual: 364 CCA
    The guy said I need it replaced and gave me the print out to take to toyota
  2. Apr 23, 2009 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks like ya need it replaced.
  3. Apr 23, 2009 at 7:08 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    good deal man!
    I still need to figure out why my truck goes dead after sitting for 2days...
  4. Apr 23, 2009 at 7:08 PM
    DanGer
    I'm hoping toyota agrees tomorrow at 1:15!
  5. Apr 23, 2009 at 7:09 PM
    DanGer
    I feel dumb asking, but seeing my current situation, have you taken it to advanced auto or other store to have it tested? Mine came back positive for HIV and low cold crank current :p
  6. Apr 23, 2009 at 7:25 PM
    dually
    dually Low and slow
    Its my Emanage system drawing current, even when the ignition is off... oh well.
  7. Apr 23, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you install a master switch without affecting it?
  8. Apr 23, 2009 at 7:26 PM
    DanGer
    oh i forgot to ask, do the numbers mean my speaker amplifier is definitely NOT causing any problems?
  9. Apr 23, 2009 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cant tell from the numbers you put up, but I doubt it. It should have a remote turn on/off, so if the truck is Off, there should be no current sent to it. If it has a "Power" LED, check to see if its iluminated when the truck is off.
  10. Apr 23, 2009 at 7:30 PM
    DanGer
    shit its under the seat haha. I was just thinking that somehow staying on is the only reason I could think of for the battery draining. If the battery isnt caputski anyway that it
  11. Apr 24, 2009 at 11:39 AM
    DanGer
    Took it to the service department, and had a fresh battery in within 40 minutes. No cost to me :)
