battery disconnect, computer relearn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brownbagg, Mar 11, 2011.
  1. Mar 11, 2011 at 10:23 AM
    brownbagg
    brownbagg [OP] New Member
    Had to clean the battery terminals and now the motor wont idle, so everytime I push in the clutch engine dies to low idle. all I did was the terminals. I know the computer has to relearn but its been 600 miles already. Its a little dangeous in town when the engine dies and you lose power brakes and power steering.
    How can I force the computer to leran, all I did was the terminals
  2. Mar 11, 2011 at 12:04 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Disconnect the battery again..... essentially, to RE-SEAT the connections.
  3. Mar 11, 2011 at 12:11 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I had to disconnect my batt yesterday for about an hour. I noticed now that my truck idles really low now. Not causing a problem,but is was enough of a drop to notice. On the other hand,it seemed to fix my horn that was not working.
  4. Mar 11, 2011 at 12:12 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Also, Check your battery ground just in case, could be a smidgen loose, doesn't take much. And wire brush away any rust
