Battery disconnect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12retire, Dec 3, 2024.
  1. Dec 3, 2024 at 10:26 AM
    12retire
    12retire [OP] •••••••••••••
    So Cal
    2014 TRD Off Road. Pyrite Mica
    Just want to know others thoughts on this. I have a 2014 Tacoma with the V6. I drive it maybe once a month. Im thinking on installing a battery disconnect on it just to keep my battery fresh. Is it worth it or is it more hassle for the truck to reset the computer settings. I have one on my gf Pontiac because of a parasitic drain and it works well. My truck doesn't drain the battery though.
  2. Dec 3, 2024 at 10:33 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    I would just get a "smart" trickle charger if you can.
    szidls and inwood customs like this.
  3. Dec 3, 2024 at 10:37 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Should be no need to unhook it as 2nd gens have a very low parasitic load if everything is working properly
    A battery maintainer would be a better option to prolong the life of the battery if it's parked somewhere near a power source.
  4. Dec 3, 2024 at 10:38 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    I would probably go for a trickle charger instead just to not have to deal with the ECU relearn process. Being driven once a month should be enough to not kill the battery but a trickle charger with sensing ability would be better.
  5. Dec 3, 2024 at 11:40 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have a Ctek smart charger. It comes with a quick disconnect that you attach to you -/+ terminals. It’s just basically a pigtail that remains there even when not in use. When you want to top off your battery, just plug it in.
    I do this to keep the battery topped off when it’s not driven much. It’s fast and simple.
    12retire[OP] likes this.
  6. Dec 3, 2024 at 12:20 PM
    545 Well-Known Member
    2015 Access Cab
    SoCal?
    Id add a solar battery charger
    WOODY2 likes this.
  7. Dec 7, 2024 at 10:02 PM
    High Desert Taco
    High Desert Taco Well-Known Member
    Wyoming
    2012 Pyrite DCLB
    The suggestions for a maintainer are spot on as far as battery health and longevity go. The only advantage a disconnect has is theft prevention.
  8. Dec 8, 2024 at 7:01 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I'm a fan of solar maintainers if there's a convenient place for it. I had a westy camper that had an annoying parasitic draw so I hooked up a small solar maintainer. The camper sat for 2 years untouched when I was overseas and started right up when I came back to the states.
  9. Dec 8, 2024 at 8:05 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You don’t have a problem. Don’t fix something that ain’t broke. I wouldn’t do anything to it. Although I wouldn’t do anything to it I would probably drive it a couple more times a month running errands and such.
    12retire[QUOTED][OP] likes this.
  10. Dec 8, 2024 at 12:35 PM
    12retire
    So Cal
    Your probably right about that. Never had a problem with the battery drain
    Sprig[QUOTED] likes this.
