SOLD - Battery Doctor Battery Isolator, with Bussman Circuit Breaker, wiring
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by rideexileex, Dec 18, 2024.
Thread Status:
Not open for further replies.
  1. Dec 18, 2024 at 11:42 AM
    rideexileex
    rideexileex [OP] Well-Known Member
    Sean
    Denver
    2000 4Runner
    SSSSOOOOLLLLDDDDDD - 100 Amp Battery Doctor Battery Isolator, mounted on a welded/modified bracket to fit under the factory battery location (I ran a long ziptie around the battery), pre-wired using very flexible welding cable with soldered copper lugs, along with a Bussman 100A Circuit Breaker. The coiled length of cable was enough to run around the perimeter of the engine bay to a 2nd battery I had mounted where the ABS unit is in a 3rd gen 4Runner. This was used for maybe a year, then hit the shelf.
    The GROUND wire can be ran through a switch to keep the system in full manual control. The Isolator can be manually switched to self jump a dead starting battery.
    I'll let this whole ready-to-install kit go for $100 shipped or reasonable offers.
  2. Dec 18, 2024 at 3:22 PM
    rideexileex
    Sean
    Denver
    2000 4Runner
    Older installed photo:PXL_20221124_183329880.jpg
Thread Status:
