Battery Drain Problem!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by claw1981, Nov 26, 2012.
  1. Nov 26, 2012 at 11:17 AM
    claw1981
    claw1981 [OP] Active Member
    Dallas, TX
    2012 Nautical Blue DCLB Prerunner
    Led's all around, tailgate lock,headlight projectors, dtrl elim, 265,75,16's, debadged, devil horns
    Hey guys need your help, my 07 taco is draining my battery everytime i let it sit for more than a few hours like overnight.after waking up to a dead battery I took my battery out when i got work to have it tested and it tested ok! when i got back to work and put it in it started right up so i thought it was fixed but no! next morning it was dead again. It charges when im driving so i know its not the alternator.. i have no aftermarket accesories, only thing i have extra is the factory alarm that came with my truck. I am stumped and dont know what to do
  2. Nov 26, 2012 at 11:28 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    do you have a multimeter? that is my first move every time.
  3. Nov 26, 2012 at 1:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Load test it... Free at most auto parts stores.
    It is probably a short in one of the cells draining the battery...
  4. Nov 27, 2012 at 8:53 AM
    claw1981
    Dallas, TX
    I bought a new interstate battery 6 months ago. I had the battery load tested at autozone and have been checking every possible light interior and exterior to make sure im not leaving any on. The only way i can get away without jumping it off every morning is by taking the negative terminal loose everytime i know its gunna sit for more that a couple of hours.
  5. Nov 27, 2012 at 8:54 AM
    claw1981
    Dallas, TX
    Yes i do, is that better than a load test?
  6. Nov 27, 2012 at 9:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    A capacitive battery tester is the most accurate test of battery health.
  7. Nov 28, 2012 at 4:16 PM
    claw1981
    Dallas, TX
    Yes the truck will fire right up if i disconnect the negative cable, and there are no aftermarket add ons on my truck
  8. Nov 28, 2012 at 5:27 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Wrong, sorry. A true load test actually pulling current is preferable. A capacitive tester won't show you if the plates jump and short when a load is placed on them. A load test can.
  9. Nov 28, 2012 at 5:31 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You'll have to do a parasitic draw test. I'm not sure how long you have to wait on our trucks but you'll need to hook up the DMM in series (10 amp setting) and then often wait 20 minutes for everything to reset and go back to sleep. Then you can see if you have an abnormal draw.
