Battery drain toyota tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newdalemccurry, Jan 31, 2025.
  1. Jan 31, 2025 at 5:55 AM
    Newdalemccurry
    Newdalemccurry [OP] New Member
    2020 tacoma
    Vehicle Modifications:
    Keep reading about battery drain on these forums. My father has a 2021 tacoma no aftermarket ad ons. The battery keeps draining if not driven dailey. If it sits a few days the battery will drain dead. The oem security is always flashing. Could that small led light be the issue. Is there anyway to disconnect security? This parasitic drain is driving us crazy. No local mechanics have any ideas.
  2. Jan 31, 2025 at 5:59 AM
    Tacoma Mike
    Southern Maine
    Bad battery
    Dirty battery
    Bad alternator
    Bad starter
    Bad door switch
    Interior door switch stuck between off and on
    Bad computer not willing to go to sleep.
    Need to get it to someone that has a solid procedure.
    soundman98 likes this.
  3. Jan 31, 2025 at 6:00 AM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    You need to find a tech that can preform a parasitic draw test starting with the A.M.A's. You could disconnect each accessories yourself one at a time to test but that would take some time. Or disconnect all and reconnect each one, one at a time till the draw goes a way. Just an idea or starting point you can do.
    eurowner and shakerhood like this.
  4. Jan 31, 2025 at 6:06 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Our trucks will kill batteries of not driven after several weeks, this is just the nature of modern vehicles. The battery dying after a few days could be a few things. 1. If the battery has been drained fully flat several times already it could just bad now and not good enough to supply the small drain our trucks have after driving and sitting idle. If he parks it in the garage and the key is left near or in the truck, this will cause systems to be active (waiting to start or unlock) and drain the battery quick. If neither of these then possibly time for some deeper diagnostics.
  5. Jan 31, 2025 at 6:28 AM
    TacoMatic4x4
    TacoMatic4x4 Well-Known Member
    87' Suzuki Samurai, 98' Toyota Avalon, 2018 Cement TRD Offroad DCLB 4x4
    For a parasitic draw, you would need to isolate the circuit in the truck that is causing the higher than normal amperage draw. A recent video from the car care nut describes how to diagnose.
    https://m.youtube.com/watch?v=2sVFcDmvAxo
    trailmeisterjoe and STEELeR43 like this.
  6. Jan 31, 2025 at 10:04 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    How old is the battery? Have an actual load test done on it? I would start there, a 4 year old battery is suspect.
    Also when driving, make sure once a week it gets a decent 20 minute or so trip. My GF's mother and father's 3 yo CRV was going through this. When the dealer and I both told him to drive it weekly, he finally listened, and it got worse. Why? We didn't think to specify "NO SHORT TRIPS!". When he did start driving it, the battery is drained from the starter motor, defrosters, HVAC on high etc while he was on his short trip to get beer and scratch offs. Frist, I put a Norco battery charger on it, and let it bring the battery back up. Secondly, he now drives at least 20 minutes before shutting it off,, no more problems. The short trips take more out of the battery, than the alternator can recharge.
    My 2019 is weak on a 1 yo battery, and after sitting (I don't drive it much, have company truck) I am going to install an outdoor outlet and put a Norco on it to keep from replacing the battery more often.
  7. Jan 31, 2025 at 1:47 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Could have one of those dealer installed tracking devices on it that they didn't tell you about, or deny they installed one.
    Chew likes this.
  8. Jan 31, 2025 at 1:52 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Might be better off with an inexpensive battery tender like "Battery Tender Junior" rather than a Norco (or any) charger .
  9. Jan 31, 2025 at 3:33 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    True, the Nocos aren't much more and are highly recommended. I also wanted slightly more amps in a small package for farm use. All that said, the Battery Tender brand seems to be solid too.
