Battery Drain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Jul 1, 2011.
  1. Jul 1, 2011 at 9:07 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    Is it possible for a car alarm to all of a sudden start draining your battery. I cant think of anything else. It is the original battery from 09.
    What I dont get is if I put a multimeter on the battery it will show over 13 volts but still will not start the truck.
    Is is possible that the battery has just gone bad? There is not anything being left on. I have not really been driving the lately...hmm maybe thats the reason...trucks parked, alarms consuming juice.. I dont know.
    thanks
  2. Jul 1, 2011 at 9:09 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    not starting up a vehicle for awhile will drain the battery
  3. Jul 1, 2011 at 9:11 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Batteries are meant to be replaced annually. A bad battery will measure 12v, it's about amperage, not voltage.
    Edit: you folks are right, most manufactures recommend replacing your battery every 3-4 years. But I agree, replace them when they're starting to go bad.
  4. Jul 1, 2011 at 9:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    You've also got the EVAP system that operates with the truck off. A dead battery will show full voltage. it's the AMPs that it won't show. You need the load test the battery for that. the easiest test is to swap in a known good battery and if it starts right up............well.........you know
  5. Jul 1, 2011 at 9:15 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    All batteries will have a little amperage drain on them from the computer etc on newer vehicles, it's called parasitic drain.
    I would suspect that your battery has a bad cell, that's what usually happend when you have full voltage but no cranking amps, an easy way to tell is to put a battery load tester on it. Something that like autozone or someone can do for you for free. When you hit the tester and the needle dives away....the battery is poop.
    Otherwise a bad connection (dirty terminals) or a bad wire will do that. But from my experience it's not typical of the Tacos
  6. Jul 1, 2011 at 9:17 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    The first part is inaccurate, unless they are just cheap ass batteries. Batteries should last years depending on the brand.
  7. Jul 1, 2011 at 9:27 AM
    808matt
    hawaii
    19 Ranger
    i still have the original battery in my 06
  8. Jul 1, 2011 at 9:35 AM
    boxxed
    Denver, CO
    09 Off Road
    OK thanks, I guess I will be pulling the battery off and getting it checked out.. It sounds like its time for a new one..This the first time I have had an issues with it..
  9. Jul 1, 2011 at 11:00 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You're right. I just want to nit-pick a little bit because I'm slightly butt-hurt. :D
    If his truck wont start, and he's getting 13v at the battery, he's probably going to get a voltage drop of 13v when he tries to start it.
    Also, there is no such thing as potential voltage. Voltage is potential difference. You shouldn't not not ever call it that. :p
  10. Jul 1, 2011 at 11:17 AM
    boxxed
    Denver, CO
    09 Off Road
    Ya its somewhere around 13v or more, I cant exactly remember I just know it was always above 12v.
    Thanks
  11. Jul 1, 2011 at 11:25 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Keep in mind you need to drive the truck a bit to replenish... If it's hard starting or reading low take it for a driver for 20 minutes and then try things out.
  12. Jul 1, 2011 at 1:44 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    There's a few common problems you can have with a battery. One of them is parasitic drain, that's where your radio, ECU, alarm, etc are all pulling a little bit of current from the battery at all times and run the charge down. With a 'normal' parasitic draw this can happen if the vehicle sits for about 2 weeks or so, sometimes even less. I've had batteries that go flat in a week of no usage. It's not so much a problem with the battery as just a sustained slow drain using up all the charge. If you tend to leave the vehicle for a period of time like this a trickle charger/battery maintainer is your best friend.
    If you have a battery that shows decent voltage but can't crank there's a couple possibilities. What's happening is the voltage us there but the current isn't. It's kind of like a kinked garden hose. You might be able to pull the trigger and get a spurt of water but the kink in the hose kills the flow right away.
    You can have this situation when the battery terminals are dirty or corroded. They make good enough contact to deliver the full voltage but not good enough to flow the full current. Pull the terminals off and clean them, that's the easiest and cheapest first step. There's a battery terminal cleaning tool available at any auto parts store.
    Corroded battery cables can do the same thing. Like cruddy build up on the inside of drain pipes it can choke off the flow.
    Next is a damaged battery. The plates in a battery can get crystalline build up on them that reduces the surface area. Less surface area = less chemical reaction = less current. This happens with time in a battery, also it can be caused prematurely by the battery sitting in a discharged condition, which is another good reason for a battery tender if the vehicle sits unused.
    You can also have plates crack and come apart inside the battery. I think they usually won't make voltage then but that can cause battery failure too. I drove down a bumpy grave road once in a car with an older battery in it, parked and it wouldn't start half an hour later. I think the vibration broke a plate loose and killed the battery.
    Generally speaking if you get 5 years from a battery you're doing pretty well. Any less I consider to be sub par and any more I would write off as being ahead of the game.
  13. Jul 1, 2011 at 2:39 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    With all this focus on the battery, you forget the cables. Make sure the connection and wires are tight and corrosion free. Check the battery and starter sides.
    If the battery tests good, check the voltage at the starter when trying to crank. If you lose more than a volt or two, either the solenoid is bad, ign is not powering the solenoid, or the cables are shot.
    Get the charging system checked when you get it running. Slow/weak alternators can cause battery failure. Three complete discharges on a NON-deep cycle battery and it is kaput.
  14. Jul 2, 2011 at 11:29 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I was just playing man. :D
  15. Jul 2, 2011 at 11:44 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    To quickly answer the question: an alarm could certainly drain your battery if it isn't run for awhile. If the truck is run often, then the alarm (or other device) could be failing and drawing high current...try measuring their current, or pulling the fuse for that device and see if it helps. Also, the battery could simply be old or damaged...take it to a local shop to be tested (autozone and the like typically do it for free).
    Other info:
    Parasitic drain is not only from the computer (or alarm in this case) but by the nature of the battery. I lead-acid battery not plugged into anything will slowly discharge, which is why there are trickle chargers.
    A few of the original posts have it right...a battery's voltage isn't the full story, it is its voltage capacity under load. A battery could be reading 12v or more but won't have the capacity to start the truck under a load (i.e. high current draw like the starter). The best way to tell is measure the voltage with the truck off and measure it while it's cranking and again while its running. The voltage will dip a little bit during cranking, but not much...I've never actually measured it, but I'd bet the voltage doesn't dip below 10V. While it's running, it will measure higher because the alternator is supplying overvoltage for charging.
    Check out my electrical basics thread for more info (link in signature). Among other things, I explain in laymans terms the electricity/water analogy. Think of a battery as a pool of water. If the pool is the size of a bucket and you punch a hole in the bottom, no matter how fast you try to refill it, the hole will always drain faster keeping the bucket empty. However, if the pool of water is the size of an above ground pool, the same hole won't be enough to drain the pool and it will always be mostly full. This is similar to your battery....the battery's capacity (i.e. size of the pool, typically displayed as cranking amps) is big enough to sustain high current (i.e. the hole) of starting. If the battery is damaged, it acts more like a bucket.
  16. Jul 4, 2011 at 4:48 PM
    boxxed
    Denver, CO
    09 Off Road
    Thanks for all the input. I was at work at the time I posted my question. Yes the problem was the fact the truck had been sitting for about 10 days or so. Since the first post I have been driving the truck with battery or charging issues....
    Thanks again TW
