Battery drain
Discussion in 'General Tacoma Talk' started by Tmar04, Jun 28, 2025.
  1. Jun 28, 2025 at 12:39 PM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    My Tacoma is old (2000) it has a battery drain when parked. Is there anything that needs to be energized 24/7 that I’m not aware of? Everything is operated pretty much manually but as soon as I switch off the engine, battery voltage drops from 14.0 to 12.7. Seems to take longer to start unless I leave charger on overnight. Thoughts?
  2. Jun 28, 2025 at 12:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Your always gona have a few milliamps of draw because even on an older vehicle there's some stuff that has keep alive power to keep memory, time, etc, shouldn't be more than 50 milliamps (0.05A) though.
    Have you actually checked it for a battery draw?
    It's normal for the voltage to drop when you turn the engine off because the alternator is no longer running and a fully charged 12v lead acid battery is 12.6v.
    SR-71A and soundman98 like this.
  3. Jun 28, 2025 at 1:19 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    How old is the battery? An old battery will start to loose voltage over time and eventually cranking amps.
    I just had a 5 year old AGM that I thought was experiencing symptoms of a parasitic draw, and then it couldn't turn the engine after charging overnight with 12.8 volts. Swapped over to my auxiliary which was purchased at the same time, but has seen a lot less use cranking the engine, and everything worked again.
    Any auto parts store should be able to load test it for you. Id put my money on old battery.
  4. Jun 28, 2025 at 1:26 PM
    Tmar04
    Terry
    Battery fine. 5 yr warranty and less than 1 yr old
    Littles likes this.
  5. Jun 28, 2025 at 1:30 PM
    Tmar04
    Terry
    Dm93. Thank you. I just thought fairly new battery would hold 13.0 v for a while. Ground lead sparks just barely enough to let you know there is a drain. But you have convinced me it’s prob normal. I’ll just keep charger handy. Great forum - great guys
    Littles likes this.
  6. Jun 28, 2025 at 1:36 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Agree. Probably normal. If you want some piece of mind and aren't familiar with the process @Dm93 was suggesting, disconnect the negative terminal and complete the circuit with a multimeter connected in-line and set to amps with the truck off and see if it's above 50 milliamps.
  7. Jun 28, 2025 at 1:37 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean typically they will hold a slight surface charge above 12.6v for awhile but it's gona drop back to 12.6 after a bit.
    Just because a battery isn't that old doesn't mean it's good though, you could fully charge it and leave it unhooked overnight then check the voltage in the morning. If it's dropped well below 12.6v it likely has an internal short developing in one or more of the cells.
    soundman98 likes this.
  8. Jun 28, 2025 at 2:01 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    If you decide to check it this way, also allow the truck to sit for around half-hour to 45 minutes or so without connecting/disconnecting anything, and all doors closed... Many vehicles post-mid-1990s or so have some circuits that need to "go to sleep" (so to say)... Before that happens, 100-200mA is typical, but afterward it should drop to around 15-30mA.
  9. Jun 28, 2025 at 2:08 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Good suggestion. When I was searching for my parasitic draw at the in cab fuses, I also used a c-clamp to hold the door sensor closed on my access cab, since you kind of need to keep the driver side door open to access the fuse panel.
    4x4junkie[QUOTED] likes this.
  10. Jun 28, 2025 at 2:11 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    This is your answer.
  11. Jun 28, 2025 at 2:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's nothing normal about having to pull out the trickle charger to get your truck started
    Just because the battery is a year old doesn't mean it's good. Simply put, asking a battery to start your car every morning is a battery test.. and it sounds like its failing that test.
    Tomorrow morning (or right now) put a multi-meter across the battery with the engine off. Should be 12.6 volts. See if the engine will start. During cranking if the voltage drops below 10.0 the battery is weak and needs to be replaced
    Or
    Turn the headlights on and walk away for 10-15 minutes. Come back and see if the battery voltage has dropped below 10. See if the engine starts. A good strong battery should still be able to start the truck even after sitting with the headlights on for 15 minutes
    These are 2 examples of a simple battery test anyone can do in their driveway
    MagicToolbox likes this.
  12. Jun 28, 2025 at 3:55 PM
    Tmar04
    Terry
    Again, my thanks to all you guys.i will do some testing tomorrow after church and report results.
    Littles likes this.
  13. Jun 30, 2025 at 6:17 AM
    Tmar04
    Terry
    Well,guess what? I checked battery voltage this morning after sitting all night properly hooked up in circuit and 12.77. So my worry was all for naught. But, you see, when you’re 86 you can get away with with it. All you guys were right. I am forever grateful.
    Littles and SR-71A like this.
  14. Jul 6, 2025 at 11:08 AM
    Tmar04
    Terry
    Now is another problem. My veh is a 2000 prerunner. When I fill up with gas. About 1 second before pump shuts off, gas leaks out under truck. Every time, every pump, every station. A
    Mx there are smell of gas fumes when I fill up all around truck and in truck. If I knew what to order would help. Thanks to all.
  15. Jul 6, 2025 at 8:33 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    that's going to be in the filler neck. there's the tank inlet, which goes to a rubber hose, which then connects to the gas cap/hose piece. i would check the gas cap/hose piece at the point it intersects with the hose for rust/rot
  16. Jul 7, 2025 at 3:27 PM
    Tmar04
    Terry
  17. Jul 7, 2025 at 5:17 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Need more info or a video while its cranking, so I can see your "taking longer to start"
    may have nothing to do with the battery....
    As stated, generally your battery car off will sit at 12.6 volts...
    Your battery car off shouldn't sit at 14.0 volts like you think.
    "bro" made a suggestion but didnt included a key element a VERY important piece of info....
    Disable the coil so the engine doesnt start.
    The battery shouldn't drop below 9.6 volts while cranking engine for 15 seconds.
    After 15 seconds of constant cranking of engine without engine actually starting, if voltage drops below 9.6 volts, battery is faulty....
    Thats how you correctly load test the battery without an actual tester.....
    Or just drive it to an auto parts store & borrow their battery tester for free...
    It may not be starting right away from other reasons like fuel pressure related issue, etc & you think its a battery issue...
  18. Jul 8, 2025 at 8:07 AM
    Tmar04
    Terry
    Thank you so much. Your suggestion made sense to me, a non mechanic. Again, my thanks
  19. Jul 8, 2025 at 8:07 AM
    Tmar04
    Terry
    I was worrying for nothing
