Battery dying
Discussion in '4th Gen. Tacomas (2024+)' started by Goin2drt, Jun 25, 2025 at 3:01 AM.
  1. Jun 25, 2025 at 3:01 AM
    Goin2drt
    Goin2drt [OP] Well-Known Member
    Well we went on vacation for two weeks. When we got back and tried to start the truck the starter clicked a whole bunch of times, then nothing. Tried again and it did it again and the truck barely turned over and started. I thought driving it around for a while would fix the issue (charge the battery) When running errands it does start back no problem. However every morning it clicks and struggles and barely starts.
    I was just going to go buy a new battery until I found out how much they were, a HATE dealers.
    Appointment Friday. We will see what they say and if they are going to replace it under warranty or not. I have VERY LOW expectations. Truck is a year old and has 20k on the clock.
    Chupacabraz likes this.
  2. Jun 25, 2025 at 3:12 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    1 year old battery and already being dead is a concern. When I don’t drive my cars for extended periods I usually have a trickle
    Charger attached to my battery to keep it topped off.
    Jakerou and Goin2drt[OP] like this.
  3. Jun 25, 2025 at 3:29 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    The battery should be under warranty with dealer . Just take it in and have them test it they should give u a new battery if it went bad .
  4. Jun 25, 2025 at 4:15 AM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    I'm by no means an expert, but I found my factory battery wasn't great either, I had to replace it after 2 years, that was through 2 canadian (-40f) winters though, with no battery blanket. 1 year is not great, I'd for sure take it to the dealer.
    Replaced mine with a motomaster with high cold crank amps and its been great so far
    Goin2drt[OP] likes this.
  5. Jun 25, 2025 at 5:23 AM
    Chupacabraz
    Chupacabraz Well-Known Member
    2025 SR5 Tacoma 4x4
    Pretty sure the battery is covered under the 3/36,000 bumper to bumper warranty. You should be fine. Not sure if these came with AGM batteries, but if not you could also take this opportunity to upgrade. Should be less than $200 for a good AGM.
    23MGM and Goin2drt[QUOTED][OP] like this.
  6. Jun 25, 2025 at 5:33 AM
    Goin2drt
    It is an AGM. Local auto parts wanted $325 for a replacement. That is when I decided I would try a warranty claim
    CrispyTacoLover likes this.
  7. Jun 25, 2025 at 5:59 AM
    Chupacabraz
    2025 SR5 Tacoma 4x4
    I got an AGM for my Outback at Wally World for $179. Seemed to work well, but only kept car for 9 months after that. But I think you'll be able to get it replaced under warranty.
  8. Jun 25, 2025 at 6:04 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Your described symptoms are a bad battery. Get it replaced under warranty.
  9. Jun 25, 2025 at 6:11 AM
    Bishop84
    Bishop84 Well-Known Member
    I’ve warrantied a few 4th gen batteries already. It’s just something that happens. They die for all sorts of reasons.
  10. Jun 25, 2025 at 6:21 AM
    77thor
    77thor Driver
    Fred
    Milwaukee, WI
    2010 Tacoma SR5
    Before you replace --- try cleaning the battery terminals & cables.
  11. Jun 25, 2025 at 6:26 AM
    Chupacabraz
    2025 SR5 Tacoma 4x4
    The OEM battery in my 2024 Outback started to only be able to keep auto stop/start engaged for 5-10 seconds. If I topped it off with my NOCO charger, it would keep it off for 1-2 minutes at the long stoplights here. But it would drop down to only 5-10 seconds in a day or two. Battery tested fine at Pep Boys, but don't put a lot of faith in that quick test.
    Anyway, I put a new AGM from Wally World in it, and ASS went back to working as it should. So that battery was less than 1 year old and was already on the outs based on the behavior. It never failed to start, but clearly didn't have the reserves it should have had.
    Point being, just because a battery is "new" from the manufacturer it can still STB fairly early in its life.
  12. Jun 25, 2025 at 6:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Any chance you've done electrical 'upgrades' of some type? If so, you may want to search the term parasitic drain and do some testing.
    Otherwise visit your dealer for a warranty replacement. Call ahead to be sure they have one in stock, particularly if they are inconvenient to you.
  13. Jun 25, 2025 at 6:38 AM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    It seems that all the batteries made within the last 3-4 years are all junk. At my work, we get in NEW KW and PB trucks straight from the factory. Within 2 weeks of being delivered to us, the batteries are dead. And these truck take 3 per truck. It sucks but what can you do.
    SR-71A likes this.
  14. Jun 25, 2025 at 7:10 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    There may have been a bad batch of batteries in 2024. There are a lot of hybrid owners complaining about their batteries being weak/dying and pointing to the addition of an alternator on some 2025 hybrids as proof that there is a charging problem. Since it seems to affect hybrids more, maybe it was the batch of batteries sent to Guanajuato.
  15. Jun 25, 2025 at 7:23 AM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    When it comes to 12V automotive batteries, your observation jibes with my experiences. I've made the observation that most batteries were made by Johnson Controls and something like 5yrs ago, they sold their automotive battery division and the company that bought it promptly offshored the whole operation. Since then, batteries have all sucked. I don't know that's the issue, but it seems to fit.
    SR-71A likes this.
  16. Jun 25, 2025 at 7:35 AM
    gpb
    Atlanta
    Ford's done recalls recently on bad batteries.
    Alternator is a red herring though IMHO - the seem to only be on Pro an TH models with a fourth AUX switch, and not on hybrids with three AUX switches.
    batacoma likes this.
  17. Jun 25, 2025 at 8:43 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My battery developed a bad cell at 33 months into my 36 month warranty. Toyota gave me a free new Toyota True Start which is now 6.5 years old.
    Be pleasant and nice to the Service people and I am sure Toyota will give you a free new battery too.
    SR-71A and Goin2drt[QUOTED][OP] like this.
  18. Jun 25, 2025 at 8:48 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    not sure if this is still true. I was told a car alternator is a bad battery charger. it is great battery topper offer. I once did the drive around thing and killed my alt. it was on a vintage German sports car. the alternator shop that rebuilt it told me the thing.
    now? I trickle charge them back up if I can. just a thought
  19. Jun 25, 2025 at 8:53 AM
    TA2016
    Oregon
    Good point. I put my charger on my battery over night and the factory battery still would not hold a charge.
    If the OP’s battery is truly bad, he should get a free new battery from Toyota.
  20. Jun 25, 2025 at 8:54 AM
    aficianado
    back to bone stock.
    I think so too. if that happened to me I would release my wife on them. that woman is a badger!!!
    TA2016[QUOTED] likes this.
