Battery/Electrical. No Parasitic draw...but what?
Discussion in '1st Gen. Tacomas (1995-2004)' started by james, May 7, 2014.
  1. May 7, 2014 at 5:45 PM
    james
    james [OP] In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    As far as I can tell with my multimeter, I don't have parasitic draw. 0.00mA. But I have this sound in the morning. Clicking over the solenoid, but no cranking. This morning I had to jump it.
    This has been happening of late. Click...click...(pray)... click...Start. I replaced the battery yesterday with a new one. I replaced the copper starter contacts in my starter 3 years ago.
    What does this sound like to you?
    Here's an mp3 upload (280Kb file)
    What's Wrong With My Truck?.mp3
  2. May 8, 2014 at 2:10 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Low charge on battery, corrosion on battery terminals, or starter solenoid contacts.
  3. May 8, 2014 at 3:18 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Sounds like a bad solenoid or the starter has a short in the windings.
  4. May 8, 2014 at 3:24 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    sounds like you need to replace the starter contacts again.
    Check and CLEAN all connections first.
    A low battery would click-click click - fast.
  5. May 8, 2014 at 3:46 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Sounds like a starter to me. Battery has enough juice to pull in the solenoid contacts and keep them there. A low battery charge would (as previously mentioned) not be able to maintain the circuit and you would hear the starter solenoid clicking...repeatedly. Your starter needs some tlc.
  6. May 10, 2014 at 7:46 AM
    james
    '98 Tacoma V6
    Thanks for your reply on my starter problem. I installed a new one from NAPA. Nippon-Denso. Turned the key and it immediately turned the engine over in a clean start, but the new starter wouldn't disengage. A cursory look on the internet suggests something called "shimming" a starter, but no one says that Toyotas need "shimming." Ever heard of this? Do you think I just got a bad (new) starter?
  7. May 10, 2014 at 8:08 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    never heard that before.
    Is it exactly the same as the previous toyota starter???
    Misaligned? will it only install one way?
    If I remember correctly, My 91 would only go in one way.
    Do you have a way to check it out of the truck.
    I used a battery charger.
    Ground to case and positive to solenoid contact.
    should operate FREELY.
    MAN thats a pain in the ass- to need to take it out again.
    keep us posted
  8. May 10, 2014 at 8:09 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    OH SHIT--your in AK--hope you have a garage!!!
  9. May 10, 2014 at 9:38 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I would run down and pick up a new starter relay and try that first. You pulled the old batt down and ran some serious juice thru it trying to start. It might have nuked or severely strained the old relay underhood in the fuse box.
    It's a 1998 relay, if you have never changed it before??.
  10. May 10, 2014 at 12:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This, I've got a bad relay now giving me fits once in a while .
