Battery going dead - 2009 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crazybayman, Jan 17, 2018.
  1. Jan 17, 2018 at 1:51 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I'm going to go out a limb here, but it's probably not an issue with the battery
    PackCon and crazybayman[OP] like this.
  2. Jan 17, 2018 at 3:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You have another problem. Most likely the regulator circuit inside the alternator. Have the alternator checked or replace it.
  3. Jan 17, 2018 at 5:02 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    So far it has been this is my 3rd battery and it seem to be holding up even under these current cold temps were having....
    No issue has been found with the Truck each and every time....
  4. Jan 19, 2018 at 12:11 PM
    crazybayman
    crazybayman [OP] Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
    That's what I was thinking. All I have are an AutoStart that doesn't work anymore, and aftermarket foglights. The local garage checked for a parasitic draw, and couldn't find anything.
    I was thinking the same, except that the battery does charge while the truck is running. My only fear is that I get the garage to do that, and they tell me "your alternator is fine" after hours of labour. Perhaps I'll have to go ahead and have it checked anyways. Thanks.
  5. Jan 19, 2018 at 12:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Into 3rd year with AGM battery :fingerscrossed:
    crazybayman[OP] likes this.
  6. Jan 19, 2018 at 12:29 PM
    TacomaMike37
    13' DCLB MGM
    Buy a multimeter and check the alternator one weekend. Its actually easier then you would think. There are helpful youtube videos out there.
  7. Jan 19, 2018 at 12:30 PM
    crazybayman
    Newfoundland
    Perhaps I'll do just that. Thanks.
  8. Jan 19, 2018 at 1:05 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    So to clarify, your current battery was installed in 2015 and a month later it started having the problems you describe currently. I doubt it’s a faulty battery as it would have died completely by now. Since after driving it , it charges the battery. First disconnect the battery and charge the battery completely, wait about 2 hours then check the voltage. It should show around 12.6 or 12.7, it may be a little higher but not lower. If voltage is normal you next need to do or have done a battery load test. If that is normal then your battery is fine and you need to find the source that is draining it. That’s a lot of drain if it won’t start your engine after only 2 days of sitting.
    One question, if the battery started dying in 2015 after 2 days of non use why did you wait 2 years to pursue the problem? There’s to many unknowns here.
    As far as what’s a good battery, you’ll get a hundred different responses here. Good luck choosing one from all the different responses.
  9. Jan 19, 2018 at 2:35 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Is it a maintenance free battery? If it’s not check the fluid level. It used distilled water. If you can see the cells water isn’t going to help.
  10. Jan 19, 2018 at 5:44 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I'm thinking Gremlins...Gremlins for sure.
  11. Jan 19, 2018 at 7:13 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Try an Interstate battery. I also agree with having a load test done.
  12. Jan 19, 2018 at 9:52 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If you are talking about Toyota TrueStart, I could not agree more. Every one I've owned bit the dust way too soon.
  13. Jan 19, 2018 at 10:00 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    My truck is 8 years old and I’m on my 3rd battery. Sounds to me like you’re doing well in comparison
  14. Jan 20, 2018 at 5:41 AM
    crazybayman
    Newfoundland
    Yeah I think you are right, something is draining the battery. I had looked into on a few occasions by getting the garage to check for a drain, and they found nothing. Been putting up with ever since. Nuisance.
    THAT HAS TO BE IT
  15. Jan 20, 2018 at 7:21 AM
    #35
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    My truck is a 2015 with 4.0 engine 162,000 miles, cold climate. Thinking of replacing battery soon instead of getting stranded two hours from home etc. while at work.
    Current battery is 27F but I see alot of places that say the correct size is 24F...whats the difference?
  16. Jan 20, 2018 at 12:54 PM
    #36
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It should be the 27F. Difference is cold cranking amps.
  17. Jan 20, 2018 at 1:36 PM
    #37
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I have the largest size battery from advance...it has lasted for about 6 years now I think with no issues....granted I have the four cylinder...which probably is easier on it.
    If you go to an advance they can check your battery and alternator free of charge.
    Forgot to add AutoZone or most of the other big part stores will also do the same.
  18. Jan 20, 2018 at 3:06 PM
    #38
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    V6's - US sold have the 24F battery or the 27F with tow package, Canadian is 27F. Don't know on I-4.
  19. Jan 20, 2018 at 3:28 PM
    #39
    moondeath
    Pa, Gardners
    Tonight I just bought a duralast gold from autozone with a 5 year warranty. Mine was original from 2013 with 71k miles. It’s been cranking slower, so I decided to just replace it.
  20. Jan 20, 2018 at 3:31 PM
    #40
    Blockhead
    Pittsburgh, Pa.
    24F or 27F?
