Battery ground wire
Discussion in '1st Gen. Tacomas (1995-2004)' started by jackn7, Nov 6, 2017.
  1. Nov 6, 2017 at 8:21 PM
    jackn7
    jackn7 [OP] Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Was just curious about the ground wire that goes from the negative side of the battery to the side of the fender well area. How important is it? I just noticed mine wasn't connected when I installed my new aluminum battery hold down (Thank you Coupe!!!). It must've broke off not too long ago when I replaced the battery.
  2. Nov 6, 2017 at 8:22 PM
    tcjacado
    tcjacado Well-Known Member
    It's fairly important as that is the main ground for all the electrical in your truck I believe.
    @TXpro4X4 What do you think, your the electrical guy
  3. Nov 6, 2017 at 8:24 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
  4. Nov 6, 2017 at 8:26 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Holy crap!
  5. Nov 6, 2017 at 8:28 PM
    tcjacado
    The entire negative from the battery cable goes there too... right??
  6. Nov 6, 2017 at 8:29 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    The main negative cable is connected. It's the smaller one that's not connected anymore.
    tcjacado likes this.
  7. Nov 6, 2017 at 8:30 PM
    tcjacado
    Ahh ok, if the main one is connected your good. What accessory does the yellow crimped wire go to? That's the one you will have a problem with
  8. Nov 6, 2017 at 8:30 PM
    Glamisman
    Glamisman Well-Known Member
    yes it is important... this insures that the items that are grounded to the sheet metal of the truck get grounded to the battery.
  9. Nov 6, 2017 at 8:33 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Okay. Looks like that's on my todo list for tomorrow. Glad it's an easy fix. Thanks to both of you for the quick replies. Really appreciate it!
  10. Nov 6, 2017 at 11:51 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The big ground cable from the battery is connected to the transmission (or maybe the engine). You need a big cable grounded there because the starter uses so much current. Also, the alternator provides all the current when the car is running and it's grounded through the engine block/transmission back to the battery.
    You are missing that ground wire to the body near the battery, but there is another ground wire from the firewall (or right fender) to the/a cylinder head, so all the power from your circuits that are grounded to body go through this wire, through the engine/transmission, then back through the big ground wire to battery. If this second ground wire got disconnected you'd lose the body to battery ground and most of your circuits (lights, etc.) would stop working, so it's good to have both grounds.
    Digiratus and COMAtized99 like this.
  11. Nov 7, 2017 at 12:58 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My ground cable next to the battery just rusted off. The one Toyota put on there is so small and flimsy. I went out to PepBoys and bought a heavy gauge starter wire and used that as the new ground cable.
    I grounded it behind the fuse box Bolt instead of where it usually is because my Morimoto HID relay mounts to where it originally was.
    jackn7[OP] and Dalandser like this.
  12. Nov 7, 2017 at 2:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Bigger in grounds is always better.
    MadNachos and jackn7[OP] like this.
  13. Nov 7, 2017 at 8:47 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I would re-do that ground. Basically you have a plastic piece shoving the cable against what looks like a painted surface. You want a clean piece of body to press against and a corrosion free bolt doing the work and touching the cable. In the world of grounds, there cannot be too many. You can pretty much ground everything that's not B+ to everything else that is not B+. The hole that is forward of where you have the cable would be better than the setup you have now.
    DrZ likes this.
  14. Nov 7, 2017 at 9:55 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's probably a good idea, I'm just working with I could with the limited space.
  15. Nov 7, 2017 at 10:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That's 1/3 of the 'big 3' upgrade.
  16. Nov 7, 2017 at 11:43 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    I was thinking the same thing as rzgkane. I like to run a tap through the bolt hole to clean up the metal threads so I get a good electrical connection from the top of the bolt to the body.
    The alternator provides all of the current when the engine is running, so I wonder if it's better to put a bigger ground cable from the body to the ground point on the transmission (where the battery cable grounds) rather than to the battery negative. It probably doesn't matter too much since the ground cable between battery and transmission is big anyway.
  17. Nov 7, 2017 at 4:27 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if your body ground isn't connected, all kind of weird electrical shit and problems can arise
    Bad grounds and bad batteries are known to cause these trucks to go mad, electrically speaking
    MadNachos likes this.
  18. Nov 7, 2017 at 6:04 PM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    I Bought my truck with no battery ground and i haven't had a problem... yet. I never really gave it much thought.
  19. Nov 8, 2017 at 8:07 AM
    rzgkane
    Your body is grounded somewhere or you'd be having exorcist type stuff happening. Just might not be grounded in the most obvious place right by the battery.
  20. Nov 8, 2017 at 7:57 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    Well said. Grounds are there for a reason and not keeping them all connected and in good shape can cause a plethora of problems that can be very hard to track down. If you are not aware of the importance of grounding, that is.
