Battery Grounding in Truck Bed
Discussion in 'Off-Roading & Trails' started by mz777, Sep 28, 2020.
  1. Sep 28, 2020 at 12:55 PM
    mz777
    mz777 [OP] New Member
    2015 Magnetic Gray 4x4 Access Cab
    Hello! I've been searching high and low for answers on this, but can't seem to find anything. I have a battery with inverter and solar setup in my camper shell, and I'm trying to figure out the best way to ground the negative terminal of the battery and the inverter post to the truck frame. My current thought it to run wire to the undercarriage of the truck, but I figure that will get incredibly dirty and stop working as intended fairly quickly. Has anyone gone through this before/have any ideas on the best approach? Thanks!
  2. Sep 28, 2020 at 1:01 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The bed bolts mount directly to the frame, I thought. You could attach your ground directly to that, instead of having to route all the way around/through the bed.
  3. Sep 28, 2020 at 9:39 PM
    mz777
    Ah, yeah, that's a great idea! I think I'll go with that, thanks @Rock Lobster!
    Rock Lobster likes this.
  4. Oct 9, 2020 at 3:05 PM
    Chako
    Chako Well-Known Member
    Utah
    1998 TRDOR M/T 2020 TRDOR M/T
    Is it bad to have two different batteries or charging systems share a ground? Specifically the ECU and important electronics on the truck?
  5. Oct 9, 2020 at 4:39 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    no. ground with is where current goes to die.
