Battery hookup SNAFU
Discussion in '4Runners' started by FJarhead, Feb 20, 2013.
  1. Feb 20, 2013 at 7:21 PM
    FJarhead
    FJarhead [OP] Member
    Autozone sold me the wrong battery and without realizing it I tried to install it. The poles were backwards and it sparked. Realizing my mistake, I exchanged it for the proper one but after connecting it, all the dash warning lights remain on.
    Any suggestions?
  2. Feb 20, 2013 at 7:32 PM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    I'd say start by disconnecting the terminals from the battery and then touching them together. This will discharge the energy from the components of the vehicle. Then reinstall the battery properly and see if the lights remain. This will reset the values in your truck as well, so shift points, gas mileage, etc... Will be erased.
  3. Feb 20, 2013 at 7:39 PM
    FJarhead
    I'll give that a try. Thanks for you advice! I'll let you know if it works.
  4. Feb 20, 2013 at 7:48 PM
    FJarhead
    I tried touching the wires together and reinstalling the battery but to no avail. Thanks for your help but I guess its time to take it to the dealership.
  5. Feb 23, 2013 at 9:31 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    First, I would check all the fuses and fuse wire, if equipped. Fuse locations will be indicated in the owner's manual. I believe you will have better luck having a good auto electric shop troubleshooting the problem than a dealership.
  6. Feb 23, 2013 at 9:44 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    HMMMMM--let us know what you find.
    Leaving the terminals--disconnected for at least 1/2 hour might help==How long did it take to go get the battery?.
    Sometimes just disconnecting them for a couple minutes does not satify the amount of time required to do the RESET.
    If the lights are coming on--if it is a FUSE--It will be on the NEGATIVE side.
    Is there a seperate NEGATIVE FUSE.
    That would be my first guess.
    I am going to GOOGLE and see if I can find anything.
  7. Feb 23, 2013 at 9:45 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    What year and engine?
  8. Feb 23, 2013 at 9:49 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  9. Feb 23, 2013 at 1:41 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    guess he got it running!
  10. Feb 23, 2013 at 2:40 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    My wife's battery went dead and some guy tried to help her with a jump start. Well the guy hooked up the cables wrong on the 4-runner and blew several of the main fuses in the engine bay. The truck would start but no electrical would work and it wouldn't go when put in gear. Well after a $400 dollar visit to the dealer and a new battery its running again. Some of the main fuses in the engine bay can only be replaced by taking the fuse box apart.
    RJM
