Battery issue or what?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe23, Mar 14, 2017.
  1. Mar 14, 2017 at 7:08 PM
    #61
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    When it had trouble the original time. Was it sitting out in the cold for awhile and were you making shorts trips with the Truck?
  2. Mar 14, 2017 at 7:11 PM
    #62
    Herniator
    Edmonton
    The whole time reading this thread. I am thinking I am so glad that I don't have my old Jeep anymore. The Jeeps were known to have charging problems. It didn't help that Chrysler put the Voltage regulator inside the computer of the Jeep. Rather then in the alternator or someplace where you can change it.
    Joe23[OP] likes this.
  3. Mar 14, 2017 at 7:12 PM
    #63
    Joe23
    Joe23 [OP] Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    it's been parked in the street since I got home from work, so about 9hours.
    When I went to move it into the driveway it started fine no problem.
    Pulled forward and turned to get parallel to the driveway, then backed in.
    After I parked in the driveway and turned it off, got out and realized I was a bit too close to the other car as I couldn't walk between them, so got back in to pull forward a little and thats when it hesitated.
    Was basically the same the other time it happened just reverse. Got in to move it so I can get the other car out of the driveway, then went to put it back in and it hesitated to start again.
    Both times truck ran for under 1 minute.
    So yes it was definitely short cycled. and both times it was around -10C out if not colder.
  4. Mar 14, 2017 at 7:44 PM
    #64
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Well no wonder Klein tools are so dammed expensive at Home Depot...
    haha
    Joe23[QUOTED][OP] and smitty99 like this.
  5. Mar 14, 2017 at 8:11 PM
    #65
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    This thread made me grab my Battery Tender trickle charger for my spare Optima Yellow Top that I have in my storage. You are correct that they are no where near as good as they used to be; but they are still a solid choice. I still prefer Odyssey batteries though.
    I ran both in my Acura TSX and I will say even with a hopped up stereo I couldn't kill either one. The Odyssey just seemed to be of higher quality. Or it could be that Optimas are made in Mexico and Odysseys are made in the USA or the UK; which shows how big of a bias I have.
    shakerhood and Joe23[QUOTED][OP] like this.
  6. Mar 14, 2017 at 9:17 PM
    #66
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    My S2000 has a non sealed die hard in it, and my 2x motorcycles and lawnmower batteries are non sealed. Just sayin.... :bananadance:
  7. Mar 15, 2017 at 6:20 AM
    #67
    Joe23
    Not sure about there. But for common things like pliers and screw drivers they're roughly the same price as suppliers. Maybe $1-3 more. But for me if I need it I need it that moment. Most suppliers don't keep much in stock for tools and it's a few days to get in. If I blow up a pair at work I likely need them again tomorrow so have to go to home Depot as they always have stock.
    For other more specialty thing though way cheaper at suppliers. Nut driver set is about $20 cheaper from suppliers.
    Any insulated tools are cheaper from suppliers as well. Mind you home Depot here doesn't really carry much for insulated.
  8. Mar 15, 2017 at 6:52 AM
    #68
    Herniator
    Edmonton
    Where I live, there are quite a few suppliers that carry a better selection of Klein tools then Home Depot does.
    Joe23[QUOTED][OP] likes this.
  9. Mar 15, 2017 at 8:11 AM
    #69
    Joe23
    The suppliers here have a better selection but they're marginally cheaper
  10. Mar 17, 2017 at 10:08 AM
    #70
    Joe23
    So was at the dealer having my tonneau cover fixed with one of the retaining clips that was started at the beginning of feb since they took so long to get it in, and while they were doing it got them to check the battery.
    They didn't check levels but did a battery test
    results
    Rated at 582 CCA
    Tested at 677CCA
    So according to them the battery is fine, so figures they can't do anything
    Guess time will tell, battery is shit anyways and I was planning on doing a swap eventually.
    shakerhood likes this.
