Battery issue?
Discussion in 'Technical Chat' started by NSTacoma, Jul 1, 2016.
  1. Jul 1, 2016 at 8:29 AM
    NSTacoma
    NSTacoma [OP] Member
    2003 Tacoma Double Cab 4x4
    I've tried googling this but I am not having any luck..
    My battery can not hold a charge (i think) but the multimeter is telling me my amps are good.
    It says; ~12.5 with engine off and ~13.9-14.2 while under load. It did drop to ~13.5 after idling for 10 minutes with the HVAC cranked, a/c on, radio on, and every light turned on.
    I can jump start it no problem. Drives fine. But when I shut it off I can crank the engine over a couple times before it goes tictictictic and wont start. It still reads ~12.5 when it won't start.
    This started happening two days ago after I picked my truck up from having my wheel bearing replaced. They disconnected the battery because they were working on the ABS (wheel speed sensor). But, right before I dropped the truck off I jump started my sisters car and sprayed some mud out of my engine bay with a hose.
    There is a sticker on the battery that says 1/09 so i'm guessing it is over 7 years old.
    Is the battery the problem? (even though the amps are good)
  2. Jul 1, 2016 at 8:38 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You're lucky you got 7 years out of you battery, they usually last on average about 4 years. Go get yourself a good quality battery and you'll be good to go.
    Rambo MARINE Recon likes this.
  3. Jul 1, 2016 at 2:38 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You might also have a poor ground condition .
    Your reading Volts not amps .
    What reading do you get after it sits all night ??
    That is the important one
    As long as the battery reads 12 VDC(engine off) it does not appear to be the battery
    Are your battery terminals clean and tight not broken??
    Has the starter ever had attention ??
  4. Jul 1, 2016 at 3:24 PM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    replace with a AGM Glass Matt Battery for less than $200 at Pep Boys,Autozone,Oreillys,Advance Auto Parts ,or NAPA and More. Much better than what you have now and check and clean all ground straps and terminals at battery !
  5. Jul 15, 2016 at 11:43 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Typically your symptoms are a bad cell. Once the draw on the battery it drops below so it cant crank.
  6. Jul 16, 2016 at 12:57 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am happy if I get 2 Years out of any battery .
    Most all the battery vendors I deal with don`t care for the AGM batteries not worth the extra money
    As I can buy 2 regular batteries for the price of one AGM
    For my use it is not cost effective yet!!
