Battery issue.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DEVIAT3D, Feb 27, 2017.
  1. Feb 27, 2017 at 3:16 PM
    DEVIAT3D
    DEVIAT3D [OP] Member
    Kapaa HI
    2017 Blue Tacoma Offroad
    Non yet
    I picked up my NEW truck on thursday around noon. I been noticing that when i turn my key to the second click position, it says check charge system anyone else have this issue?
  2. Feb 27, 2017 at 3:18 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Mine does that when I turn the power on (not start the truck) with the push button. Probably because you're draining battery but the alt isn't running.
  3. Feb 27, 2017 at 3:18 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Is the light on when the truck is running?
    It will show that if not running, its telling you the alternator is not charging, which it will not unless the engine is running.
    If the light is on while engine running there is a problem, otherwise all normal operation.
    CusterFan and DEVIAT3D[OP] like this.
  4. Feb 27, 2017 at 3:19 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Normal
  5. Feb 27, 2017 at 3:19 PM
    DEVIAT3D
    Kapaa HI
    Non yet
    but it shouldnt happen right away, it should tell you that when your battery is almost dead right?
  6. Feb 27, 2017 at 3:20 PM
    daddy_o
    Bossier City, La
    No, its telling you its not charging, not the battery level.
  7. Feb 27, 2017 at 3:22 PM
    DEVIAT3D
    Kapaa HI
    Non yet
    thanks
  8. Feb 27, 2017 at 3:25 PM
    OdiN1701
    Colorado
    Yup, because if your alternator went out you would want to know right away, not when the battery is almost dead from no alternator.
