Battery life?
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 31, 2015.
  1. Dec 31, 2015 at 3:47 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    How long will my battery last if I have it on accessory and just run the radio on low volume?
  2. Dec 31, 2015 at 3:52 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Depends on the battery. Results will vary
  3. Dec 31, 2015 at 4:04 PM
    goldentaco03
    Liam
    NJ
    What's a general estimate I have a stock battery
  4. Dec 31, 2015 at 4:13 PM
    robssol
    Rob
    S. Wisconsin
    A '03 with the stock battery? 13+ years! I wouldn't push it! 0 min!
  5. Dec 31, 2015 at 4:24 PM
    goldentaco03
    Liam
    NJ
    Stock as in I don't have a new deep cycle battery it's just some Napa battery nothing special.
  6. Dec 31, 2015 at 4:55 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    depends on what the reserve capacity says on it. the sticker up top should tell you 4 things: part number, cranking amps, cold cranking amps, and reserve capacity. not all batteries say the reserve capacity since automotive batteries weren't made to provide reserve capacity. reserve capacity is the job of deep cell batteries.
    im going to go off a limb here. our trucks use a 24f battery. im going to assume you bought the 84 (premium series) battery. the part number should say 8424f on the top. the reserve capacity on the 8424f is 130 minutes.
    additionally the 7524f battery has a reserve capacity of 110 minutes. and the 6524f battery has an RC of 95 minutes. IF YOU HAVE A GROUP 35 BATTERY. I suggest the next time you replace it you switch it to a 24f since its more powerful. but before you do switch. inspect the battery tray and make sure you can fit a wider battery.
  7. Jan 1, 2016 at 5:57 PM
    Indy
    Indy Master of all I survey.
    And your truck wont start anywhere close to 10.5v, i dont think even the radio will work at 11.
  8. Jan 5, 2016 at 5:04 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    i have an optima yellow top in mine out of my old truck (950 CCA 185 min res. time) and i can run the radio with enough volume to be heard over normal work noise with the doors closed windows open for about 5 hr or just slightly over before the truck no longer starts.
    the optima yellow top i have is a deep cycle battery so it is made for this type of use.
    stock 24f battery i got less than 3 hr before the music started sounding foggy and i shut it off... truck did start after this but only barely.
    it will kill a non-deep cycle (ie; standard auto) battery to do this frequently.
