Battery Life
Discussion in 'Off-Topic Discussion' started by HisDad, Jul 3, 2020.
  1. Jul 3, 2020 at 8:25 PM
    HisDad
    HisDad [OP] Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    My daughter lives in Austin, TX. She has a 2012 Civic and needed a new battery about two years ago. This week she had to jump the battery a few times and I told her have the battery checked.
    The guy at Autozone told her that it was bad and in general batteries only last about two years down there.
    It's under warranty from the dealer, so it's not like Autozone is going to sell her one.
    Up her in the frosty northeast, I generally get 4-5 years out of a battery and thought that this was the norm.
    Does the heat kill batteries that fast in the south?
  2. Jul 3, 2020 at 8:38 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Heat is the worst thing for batteries. A couple of years in Austin is about all you're going to get with most batteries.
  3. Jul 3, 2020 at 8:39 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Sadly he is not far off. Few years is about average in crazy heat
  4. Jul 3, 2020 at 8:42 PM
    HisDad
    Texas at last
    Thanks guys. Not that I'm skeptical, but sometimes she is a bit too trusting and I wanted to confirm what she was told.
    suaveflooder likes this.
  5. Jul 3, 2020 at 8:47 PM
    Bishop84
    Bishop84 Well-Known Member
    Heat is way harder on batteries. Most cold weather batteries last on average 5 years, hot weather is 1-3 years.
  6. Jul 3, 2020 at 8:47 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the major factor on battery life is recovery
    from the time U crank it....................to the time it becomes fully charged
    if cranked run only 30min commute ( actually the average yet Not long enuf )
    unlikely its fully charge
    no less lifestyle might allow several trips during the day
    resulting in the batt being in deficit
    next round of daily living & the battery starts where it left off
    the alternator starts charging yet
    the duration of drive still doesnt allow batt to catch up
    gradually over time the batt is & pretty much stays in deficit
    4 te years i had a mid day commute ...................didnt even have to stop until i got to work
    first set o brakes went 120k miles
    batt was always hot...........lasted over 7 years
    40 mins hi-way speed always kept batt up
  7. Jul 3, 2020 at 8:51 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    As others have said, heat is the death of a battery. A typical battery location in an engine bay is double bad. Not unusual to have a battery loose capacity in 2 years in hot climates.
  8. Jul 5, 2020 at 10:37 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The OEM battery in my Tacoma was going good after 10+ years; I replaced it out of caution. The wife's 2016 RAV4 battery needed replacing this spring. Guess the Tacoma was lucky.
  9. Jul 5, 2020 at 10:41 AM
    suaveflooder
    Wow!! That’s impressive. I don’t live in any place that gets much above 90 and it’s rare. I got a year and a half and 35k miles out of my stock one
  10. Jul 5, 2020 at 10:55 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Yes heat kills batteries, but I'm thinking 2 years isn't acceptable. It gets pretty hot here in GA, It will hit triple digits quite often July through September and I normally get 5-7 years out of one. But with most anything electrical it can be hard to predict. Some stuff dies quickly for no apparent reason, others last longer.
    The factory battery on my Tacoma lasted 8 years. The replacement only 2, but the current one is 3 years old. The battery in my Honda has been in there 7 years and I got 6 years out of the one in my F150.
  11. Jul 5, 2020 at 11:31 AM
    JEEPNIK
    Something today’s batteries have to deal with, and it will only get worse is parasitic draw. As bad as heat is that slow draw takes a toll.
    If you don’t drive almost daily, and long enough to fully recharge the battery a battery maintainer would be a wise investment.
  12. Jul 5, 2020 at 2:02 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Check the water in your cells periodically, I always need to add a little distilled water in the 2 cells adjacent to the pos and neg post. My truck is always outside and it’s a cooker under my mgm hood.
  13. Jul 5, 2020 at 6:59 PM
    ROAD DOG
    FEW
    s o m e of the new tech batteries dont have the longevity
    theyve been tested & found to be so.....................weve brought them in as backups by truckloads to routing centers
    they simply have a short shelf life
    no less when called to duty last run significantly short of specs
    the older lead/acid ' wet ' batteries were inconvenient yet
    at my company we had them last decades..................worked there 25+years
    never saw 1 replaced
