Battery light came on Dashboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaBro, Apr 19, 2025.
  1. Apr 19, 2025 at 12:14 PM
    YotaBro
    YotaBro [OP] Well-Known Member
    98 Tacoma
    Battery light came on, on the dashboard and my radio cut out while driving home. A couple minutes later the light went off and everything back to normal.
    First time i've ever had this happened. Anyone know whats up? Alternator going out?
  2. Apr 19, 2025 at 12:16 PM
    bwise
    bwise Well-Known Member
    Low battery voltage is what that means. Any auto parts store will test your battery for free and tell you if it’s bad. I’d start there
    23MGM likes this.
  3. Apr 19, 2025 at 12:32 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    If the battery tests good, then check the alternator
  4. Apr 19, 2025 at 12:58 PM
    YotaBro
    98 Tacoma
    this battery is relatively new (1-2 years old) so i don't think it would be an issue. how do i check the alternator?
  5. Apr 19, 2025 at 1:22 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    With a volt meter or old school way of starting the truck then disconnecting the negative cable at battery. If it shuts off, alternator is weak or bad. If the truck remain running, good alternator. Lol
  6. Apr 19, 2025 at 1:29 PM
    oldtimertoyota
    New Mexico
    I would also check and make sure that your grounds are actually grounded
  7. Apr 20, 2025 at 11:15 AM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    This is happening to me, now, on a 2005 at 243k miles on the 2TR-FE (original alternator). I replaced the battery, light comes on/off. No corrosion in terminals or cables.
    YotaBro[QUOTED][OP] likes this.
