battery light flashing on dash?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Komar, Dec 8, 2009.
  1. Dec 8, 2009 at 8:29 AM
    Komar
    Komar [OP] Member
    Does anyone know what could be causing my battery light on the dash to blink once in awhile. The truck seems to start and run fine. Its a 96 tacoma 4x4
  2. Dec 8, 2009 at 8:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your altenator may be on it's way out.
  3. Dec 8, 2009 at 8:35 AM
    Komar
    Komar [OP] Member
    yeah,, maybe I should take it and get it checked
  4. Dec 8, 2009 at 8:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    Best thing to do IMHO.
  5. Dec 8, 2009 at 8:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    I've never heard a tacoma (or other yota) do that. :notsure:
  6. Dec 8, 2009 at 8:39 AM
    Komar
    Komar [OP] Member
    I think pep boys will do it for free. I need to pull it out I think though. thanks
  7. Dec 8, 2009 at 8:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, most auto parts stores will do it free. Check your battery terminals too for corrosion and tightness.
  8. Dec 8, 2009 at 8:44 AM
    Komar
    Komar [OP] Member
    will do! It has 170,000 on it, so I am starting to see things go more now.
  9. Dec 8, 2009 at 9:01 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2... do that first...
    also, how old is your battery?
    what kinda battery you running?
  10. Dec 8, 2009 at 9:29 AM
    Komar
    Komar [OP] Member
    battery is about 6 years old, maybe more. I would have to check. It is a pep boys replacement. It cranks fine though.
  11. Dec 8, 2009 at 11:31 AM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    Use to be 7 years on a automotive battery was about the extent of a batteries life. At 6 years old you might consider replacement of it. Depending on where you live a good cold snap will tell the tale of how good a battery is. I had one that had a shorted cell, took a diode out of the alternator but still cranked pretty well so far as I remember. That was in a 1966 Pontiac Grad Prix though.
    If the alternator checks out and the drive belt has some age you might replace it to.
