battery light flickering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Jan 26, 2012.
  1. Jan 26, 2012 at 4:57 PM
    650H1
    650H1 [OP] Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    so i took my new truck (08 tacoma DCSB 4x4 trd off road) thru the car wash today for the first time... and the battery light starting flickering like 3 minutes after i left on my way home. sometimes it was steady for like 2 seconds and then it would just flicker. most of the time its flickering. i checked all the connections, nothing was loose. i panicked and immediately called the dealer since the truck is 3 days old to me. they said come right in and well look. they checked it and said everything was fine, and showed me the printout saying it was fine from the battery and alt test machine. it stopped flickering on my way into the dealer and didn't obv do it for the techs. then on my was home it starting snowing/raining and it friggen started doing it again. WTF. i bought some electrical contact cleaner and sprayed it on both terminals to the battery and ground. anyone ever hear of anything like this? what could be getting wet and causing it? its kind of discouraging.. btw the truck has 60k on it and i was looking thru all the past maint records and it looks like the positive terminal was replaced on nov 30th 2011. I'm thinking maybe a new optima red top????
  2. Jan 26, 2012 at 5:17 PM
    650H1
    Michael
    VA
    anyone?
  3. Jan 26, 2012 at 6:16 PM
    650H1
    Michael
    VA
    bump
  4. Jan 26, 2012 at 6:21 PM
    reiss91
    reiss91 Well-Known Member
    Mark
    Mass
    2011 Tacoma Gray
    Id start by checking for loose connections at the terminals, the alternator, and even the engine/chassis grounds if you wanna go that far.
    Also check the voltage of the battery before and after the motor is running to test the alternator output. If you have a good battery tester it will give you the the CCA output that you can compare with the spec on the battery to determine if its good or not.
    Usually the light comes on due to low or high voltage and charging issues.
  5. Jan 26, 2012 at 6:26 PM
    650H1
    Michael
    VA
    alright say they aren't loose but the water is obv effecting them. what do i do at that point? white lithium grease?
  6. Jan 26, 2012 at 6:54 PM
    650H1
    Michael
    VA
    I'm thinking maybe a bad alternator belt or voltage regulator. does that make sense to anyone? do my symptoms sound right?
  7. Jan 26, 2012 at 6:59 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Take both leads off the battery. Clean both of the post with sandpaper and the leads going to the battery. Do the basics before you begin digging deeper.
  8. Jan 26, 2012 at 7:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
  9. Jan 26, 2012 at 7:12 PM
    650H1
    Michael
    VA
    We're getting all kinds of snow and rain and shit tonight. If its gonna do that every time it rains that sucks. It mostly does it when I accelerate too, or rev up in park. Is it getting over charged you think?
  10. Jan 26, 2012 at 7:32 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    if it does it when you rev up, the alternator is malfunctioning. Put a multimeter on it, and see what its charging at. I dont trust any of the machines other then the good old multimeter.
  11. Jan 26, 2012 at 7:34 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    If you can disconnect the battery while the truck is running, and it stays running, battery problem. If it cuts off, alternator problem. Like I said though, start simple. Clean the terminals and reconnect the leads tightly. Do that and keep us posted. Sub'd.
  12. Jan 26, 2012 at 7:35 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    you cant do that with the newer technology, please dont. You will definately smoke your alternator.
  13. Jan 26, 2012 at 7:35 PM
    650H1
    Michael
    VA
    Yea idk it only does it sometimes and seems to be when it's wet. I had the truck for 3 days and it didn't do it until I got a car wash. It does it when I go over bumps or sometimes when I rev up. It only flickers and is not ever steady or blinking.
    I took it in tonight and they told me everything checked out fine. That pisses me off because now I have to wait until Tuesday to go back because of work all weekend. I'll try cleaning it all up in the am but idk wtf is wrong with it
  14. Jan 26, 2012 at 7:37 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    they will flicker if the connections loose, or your belt could be loose slipping on your alternator pulley. Take it back asap, could be a hidden problem:rolleyes:
    Leave it, and get a loaner
  15. Jan 26, 2012 at 7:40 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Go with the service tech thru their drive thru wash and drive it around the block in attempt to duplicate the problem.
  16. Jan 26, 2012 at 7:42 PM
    650H1
    Michael
    VA
    ^ yea dude they always just tell me nothing is wrong and I can't blame them because it's never friggen doing it by the time I get there. I made an appt for Tuesday I'll see if they can switch out batteries and see if it makes a difference
  17. Jan 26, 2012 at 7:45 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sounds like bad alternator regulator.
  18. Jan 26, 2012 at 8:17 PM
    650H1
    Michael
    VA
    ^ where is that located?
  19. Jan 26, 2012 at 8:20 PM
    dYL0n
    Dyl0n
    New Orleans, LA
  20. Jan 26, 2012 at 8:26 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I thought if you disconnected the battery terminals while the truck is running it would destroy the computer with the newer systems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
