Battery Light flickering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WolvPro, Jan 6, 2020.
  1. Jan 7, 2020 at 10:34 AM
    Waasheem
    Waasheem
    2007 xrunner
    Nice. I think I’ll add this to my plan ok attack when testing questionable alternators. As a forklift mechanic, the chassis usually wears out or is destroyed by a idiot operator before the engine or alternator, at least in modern machines.
  2. Jan 7, 2020 at 2:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My last alternator was from AutoZone. I have no fear of them. It's warrenty is good with me.
    six5crèéd likes this.
  3. Jan 22, 2020 at 5:29 AM
    WolvPro
    WolvPro [OP] Member
    2009 Tacoma Prerunner 4x2
    6" inch lift, 2015 sport front clip swap
    Update. I got a remanufactured alternator Denso brand from Rock auto and haven’t noticed the light flickering since.
    Muddinfun, six5crèéd and Markcal like this.
  4. Jan 22, 2020 at 6:04 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Good job - Well done!
  5. Jan 22, 2020 at 6:18 AM
    Markcal
    Markcal Well-Known Member
    Thanks for updating this thread with what solved the problem, wish more members here did the same when starting a thread, as others here can learn from it. :thumbsup:
    Muddinfun, koditten and six5crèéd like this.
  6. Jan 22, 2020 at 6:26 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I just put one on mine from Advance, warranty is good and when it fails (hopefully 15 years from now) I just hope it doesn't leave me stranded.
  7. Jan 22, 2020 at 6:08 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’m glad you got it to no longer light up the battery light.
    Now that you know for certain the alternator is good I’d suggest you test your battery.
    If your multimeter has peak high and low function, you can do this test. Connect meter to the battery, + to +, - to -. Set it for dc volts peak low, start the engine. The meter will record the lowest the battery voltage dropped to. Now with the engine running switch the meter to dc volts without peak hold. Charging volts should be maxed at 14.2 or so. The old alternators would max out at 14.7. With a 14.7 alternator, a drop below 10.5 is considered a bad or weak battery. I’ve tested brand new engines with a 14.2 alternator and get 10.2 so below that is what I’m considering weak. Usually, a obviously bad battery will crank slower and test below 10. There are other ways to test your battery like a dedicated battery tester. Or an electrolyte tester but of course it won’t work on a sealed battery. Ez red makes a good electrolyte tester I like.
  8. Jan 22, 2020 at 6:13 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If your battery is older than 5 years, I would replace that too, just to be proactive.
