Battery light flickers upon startup.
Discussion in 'General Tacoma Talk' started by doveguy, Jan 31, 2024.
  1. Jan 31, 2024 at 9:00 AM
    doveguy
    doveguy [OP] New Member
    2006 Gray Tacoma 4wd
    I am new to this forum. I have a 2006 Tacoma 4x4. I am currently living in Mexico. Upon startup most days, my battery light flickers and then turns off within a couple minutes while driving. It does not come on while driving after the warmup. If I wait a day and start it up it comes on again. I thought it might be a worn serpentine belt but I just had it replaced and it is still happening. I am really not in a great location to replace the alternator but I would like some input as to how to test it to make sure the alternator is good.
    Williston likes this.
  2. Jan 31, 2024 at 5:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Jan 31, 2024 at 5:41 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Yeah thats your alternator going out. It wouldn't hurt to check the electrical connector on the alternator is secure, remove and and click it back in place. A month or two ago my running voltage dropped down to 11-12 volts right after startup with no accessories on then went back to normal 13v after a min or two, but 3 or 4 days later the battery light was on when I started it and the alternator wasn't putting out anything.
    The 4.0 alternator isn't to bad, took me about 2 hours to get my swapped out, first time changing the alternator on a Toyota but I am a professional mechanic so I do have general experience. I do remember taking it out the top of the engine bay and having to bend the hard ac line about a inch or so to get squeeze it out.
  4. Jan 31, 2024 at 7:43 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
  5. Feb 4, 2024 at 8:30 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    As others have said, the alternator is likely on its way out. The battery light in the Tacoma is one of the few out there on cars that actually tells you exactly what the problem really is. For the majority of others it could be anything: belt gone, battery on it's way out, low charge at idle. In a Tacoma at least, it's always an indication/telling you the alternator is on it's way out. I have had cars with an "Alt" lamp that never came on even when the car died from a dead battery and left me stranded.
