Battery light, low voltage..anything other than alternator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pbfender15, Apr 8, 2025.
  1. Apr 8, 2025 at 12:39 PM
    Pbfender15
    Pbfender15 [OP] Well-Known Member
    multiple 1st gens
    Heya All:
    2000 single cab 2.7L 5spd 180kmi. Mechanic put a new alternator in about 3 months ago. Battery light came on the other day. Multimeter shows 12.24 volts on the battery with engine off. Engine running shows 11.69 volts, and with headlights on it drops to 11.49 volts. All tests taken on the battery terminal studs. All the fuses under the hood appear fine.
    Any ideas what's causing battery light and low voltage, considering its running a brand new alternator...? Other tests I could do to isolate the issue?
    Thanks for the help!
  2. Apr 8, 2025 at 12:41 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Alts bad. Did you get a Denso or a cheap aftermarket alt?
    MadNachos likes this.
  3. Apr 8, 2025 at 12:59 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Aftermarket sucks...they want last 3 months
    TnShooter likes this.
  4. Apr 8, 2025 at 1:20 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Probably a "spray and pray" rebuild, buy a Denso.
    Steves104x4 and HondaGM like this.
  5. Apr 8, 2025 at 4:41 PM
    Pbfender15
    multiple 1st gens
    Hey, thanks everyone for chiming in -- confirms my guess.
    Indeed, cheap aftermarket -- has a Car Quest sticker on it. I usually do my own work and would have done a Denso, but it was mid-winter crusty rusty alternator swap so sent to the mechanic. I think they'll warranty it all.
  6. Apr 8, 2025 at 4:53 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Double check the 7.5 amp ALT-S fuse.
    hinmo24t likes this.
  7. Apr 8, 2025 at 4:54 PM
    MadNachos
    Car Quest may be OK, just bad luck, but the Denso rebuilt units are the way to go.
  8. Apr 8, 2025 at 5:29 PM
    theesotericone
    Bishop CA
    Even if they cover it all get the Denso if you can afford it. In my old 88 Toyo Van I went through 3 cheap "lifetime" alts in a year before I finally just put the Denso in. Lesson learned.
    Nice pic of Fitz Roy BTW. I got some buddies that should be coming back for El Chalten soon. Should be some good stories.
  9. Apr 8, 2025 at 6:52 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Get new meter leads
  10. Apr 9, 2025 at 2:26 AM
    Pbfender15
    multiple 1st gens
    Thanks -- I did check that one specifically but will double check!
    Thanks, multi meter is brand new...
    Moonrman[QUOTED] likes this.
  11. Apr 9, 2025 at 2:41 AM
    Pbfender15
    multiple 1st gens
    Thanks, good advise -- I'll see what they can do this week on putting in a Denso. I've tried to get them to use genuine parts in the past and they don't because they don't have an account with the dealer, it seems.
    Cool you recognize the photo -- I've spent a fair amount of time in Chalten and the southern cone. On the trip of that photo I paddled the full length of the Santa Cruz river (carries the meltwater from there to Atlantic). Didn't see a single person for 10 days.
  12. Apr 23, 2025 at 10:23 AM
    Pbfender15
    multiple 1st gens
    Closing this post out --- yes to Alternator fail. Car quest Alt. lasted 3 months. All parts and labor under warranty. Did not upgrade to Denso as caused shop complications, and after 14 years I'm letting this truck go later this year. Thanks y'all --
  13. Apr 23, 2025 at 12:29 PM
    Glamisman
    Glamisman Well-Known Member
    Where in the US are you located... I have people asking if I know of 1st gen Tacomas for sale all the time. Odd thing, 3rd gen 4Runners I have few lines on those, trucks, they disappear quick.
  14. Apr 23, 2025 at 12:39 PM
    Pbfender15
    multiple 1st gens
    I’m in the northeast NY/VT border area. Truck is single cab 2.7 180kmi and excellently maintained with many new parts. Runs excellent. Does have pending frame issues that will need repair. Sleeved one side but other side is due. I’ll likely post it to TW when I’m ready in summer or fall. Pm me if you want to discuss more. Thx—
  15. Apr 23, 2025 at 12:40 PM
    Glamisman
    Darn it, in So Cal.
  16. Apr 23, 2025 at 1:33 PM
    Pbfender15
    multiple 1st gens
    Rare as they may be, much better options in your area!
  17. May 22, 2025 at 2:56 PM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    Yo fellas,
    my battery light is still on,
    New battery, shows 13.1v when truck is not running.
    new alternator charging at 14.3v when truck is running.
    Checked the 7.5 fuse. its good.
    I put a new negative terminal on as well, old one was just a little beat up. still no change.
    whats next to check?
    RebelTaco62 likes this.
