Battery light on dash stays on?
Discussion in 'Technical Chat' started by vitang, Oct 11, 2010.
  1. Oct 11, 2010 at 8:53 AM
    vitang
    vitang [OP] Well-Known Member
    diamond bar
    07 TRD Sport 4wd
    Engage Front Long Travel, Giant Rear Long Travel, KR Fab rear bumper, tire gate and Jerry Can cage.
    The battery light on my 05 tacoma stays on the dash. I did a search on the post and found that my alt could be the culprit because its not charging the battery. Got that replaced and drove the truck for 2 days and now the battery light is back on.
    Does anyone know what the problem may be?
  2. Aug 17, 2017 at 10:16 PM
    MusicSOB
    MusicSOB Member
    Kelly
    2011 Black Tacoma V6 4WD
    I am having the same problem with my 2011 Tacoma. I had my battery tested and I was told it was fine. I recently installed OEM fog lights and a 52" LED light bar on the hood of the truck. I thought it could have been the way I wired it, so disassembled the wires so the fog lights and light bar had no power, thinking this could be the issue. Still my battery light is on. Another thing that is weird is that when I hit a bump in the road sometime the light goes off but then eventually will come back on.
    Did you ever figure out your problem? Can someone please shed some light on my issue. This is driving me crazy that I cant figure this out.
  3. Aug 17, 2017 at 10:20 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Check the battery terminals. They are known for coroding and breaking.
  4. Aug 17, 2017 at 11:18 PM
    MusicSOB
    MusicSOB Member
    Kelly
    i actually cleaned the termials with a wire brush earlier today and made sure the fittings were secure. the terminals dont seem to be loose at all. hmmm
  5. Aug 17, 2017 at 11:30 PM
    Lateralus
    Lateralus Senior Member
    Las Vegas
    07 4x4 Off Road
    Too many to list..
    Its your alternator. The battery light is telling you it's not being charged because of a faulty Alternator. I went thought this. Then one day the battery light came on and my electrical system started to die. First the stereo cut off, then the headlights cut off. Then the truck quickly lost power and the engine struggled to make power, with in 2 mins it lost all power and would not turn on.
    BassAckwards likes this.
  6. Aug 17, 2017 at 11:31 PM
    MusicSOB
    MusicSOB Member
    Kelly
    Now is there any way I could have damaged the alternator myself by trying to wire up these fog lights and LEDs? i made sure to ground everything properly, and use the correct fuses and relays. Just curious. Thanks for the help.
    Tomate87 likes this.
  7. Aug 17, 2017 at 11:38 PM
    Lateralus
    Las Vegas
    07 4x4 Off Road
    Too many to list..
    You could have.. But if you wired them up correctly you should be good. First unplug the lights from the power source and see if the problem goes away.
    If the problem still persists then go to an auto service center you trust and have them check the alternator.
    FYI- When my alternator went, The first time the battery light turned on, it turned off after about 10 mins. Thought that's unusual... Then the second time (next day) it came on all hell broke loose.
  8. Aug 18, 2017 at 1:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Time to buy a Multimeter and learn to test things yourself
    You can test the alternator output quite easy.
    under load it should put out between 13.5 and 14.5 VDC
    You might have opened a fuse if you had not removed the negative battery terminal
    Quite possible you bought a bad rebuild I get the ones I don`t buy from Toyota checked before I leave the store.
  9. Aug 18, 2017 at 5:50 AM
    MusicSOB
    MusicSOB Member
    Kelly
    i am pretty sure i left the ground on the battery the entire time i was wiring stuff up.
    Oddly enough i drove home this moring from work(i work 3rd shift) and the battery light came on and then my entire 30min drive home was off. So it looks like i have some investigating to do this weekend. Good thing i have no plans.
  10. Aug 18, 2017 at 5:52 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Another vote for alternator here! My moms FJ cruiser with the 1GR-FE did this as well and it ended up being the alternator. Hers went out at 160k miles
  11. Aug 18, 2017 at 5:53 AM
    MusicSOB
    MusicSOB Member
    Kelly
    I only have 46k on my 2011, isnt that a little young of mileage for an alternator to fail? Im still learning about this stuff.
  12. Aug 18, 2017 at 5:55 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Time to replace with a heavy duty alternater! :thumbsup:
  13. Aug 18, 2017 at 5:56 AM
    BassAckwards
    That does seem fairly early for it to be going out, but with mass production these days, every once in a while you get a dud that goes bad early. I would try to have the alternator tested to see if thats what it is. If you have a voltmeter, you can hook it up to the battery and see if it is charging whenever the truck is on
    When the truck is off my battery sits at about 12.2-12.6v.
    When its running but cold closer to 14.0v
    When its running and warmed up anywhere from 13.1-13.6
  14. Aug 18, 2017 at 5:58 AM
    MusicSOB
    MusicSOB Member
    Kelly
    ok. I really appreciate all this advice and im going to try everything and then get back to what the problem is. I honestly am amazed with the community here. i just made my account last night in hopes to get a least one answer.
  15. Aug 18, 2017 at 5:59 AM
    BassAckwards
    Welcome aboard!:thumbsup:
    MusicSOB[QUOTED] likes this.
  16. Aug 18, 2017 at 5:59 AM
    lynyrd3
    Bill
    Welcome to TW ....hang on to your wallet :D
