Battery light on dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by Potomus Pete, Sep 22, 2022.
  1. Sep 22, 2022 at 11:29 AM
    Potomus Pete
    Potomus Pete [OP] Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Does a battery light usually mean a new alternator. 289K on this one so Im ok getting one. But my truck is running like its missing bad. To the point that I think things could be so bad that the motor could be blown. I dont think I can take it back if its not it.
  2. Sep 22, 2022 at 12:00 PM
    02hilux
    Planet: EARTH
    Easiest way to tell is to unplug your positive (+) cable from the battery terminal. Make sure it don't touch anything or else you'll run into more issue. If the vehicle turns off, you have a bad alternator. If the vehicle remain idling, you may have a bad battery.
    v5ensx, 2004Taco and Potomus Pete[OP] like this.
  3. Sep 22, 2022 at 12:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Check the voltage at the battery with a multimeter. Should be more than 13 volts if the alternator is still functioning. Ideal is +14 volts.
    If you don't have a meter, any auto parts store can check this for you.
  4. Sep 22, 2022 at 12:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Please do not unhook the battery with the engine running, it's not a very good test not to mention voltage spikes from doing so can damage electronic components. Buy a cheap meter and check battery voltage with the engine running, blower and headlights on high, you should have 13.2-14.8v.
    If the truck is running that poorly I would address that before going after the alternator.
  5. Sep 22, 2022 at 12:49 PM
    02hilux
    Planet: EARTH
    Never had an issue doing that for a number of years and on plenty of cars and trucks. I understand for newer vehicles that rely heavily on electrical but not for our first gen.
    Yes there's plenty of ways to go about this as mention.
  6. Sep 22, 2022 at 1:09 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    I do this when I suspect my battery or alternator is bad. My battery light turned on this summer, unplugged the red cable and truck remained running. Bought new battery, light turned off.
  7. Sep 22, 2022 at 1:34 PM
    Potomus Pete
    Hippy
    Gonna see what the shop says. Breaks my heart to bring it to a mechanic. If I do need an alternator lets see what they charge me, and if it;s an Advanced auto rebuilt or new. Like most, my wife goes crazy over the cost, and Tacoma alternators cost double what a Mustang would.
  8. Sep 22, 2022 at 3:12 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
  9. Sep 22, 2022 at 4:40 PM
    Potomus Pete
    Hippy
    Good one for the price. I bet the mechanic charges me $350.00 for a new one. The guy will call tomorrow.
  10. Sep 22, 2022 at 5:08 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The light can light for any charging system problem. Physical damage loose connections
    I gotta agree this is a bad practice disconnecting battery cables of running engines.
    This is a holdover from the days of generators
    If the system voltage drops to low the ECM shuts down to protect it`self might be very near that point causing the poor running.
    Good luck
    Dm93[QUOTED] likes this.
  11. Sep 22, 2022 at 5:16 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Do not disconnect while running. You can have it load tested for free at oriellys or autozone.
    Maybe pick up a cheapie volt meter and watch you tube videos to figure it out. Its a great troubleshooting tool.
    Dm93 likes this.
  12. Sep 22, 2022 at 5:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Agreed but some people still think is a valid test for some reason, at best it will tell you the alternator is doing something, at worst you will kill the PCM or some other electronics from the voltage spike.
    Bivouac[QUOTED] likes this.
  13. Sep 22, 2022 at 9:33 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Hey if your alternator is OEM I would suggest that you just replace the brushes on it, they are less than $20 from Toyota and the job does not take much longer than just replacing the alternator. These Denso alternators are super reliable, but like anything the brushes wear over time. While you’re in there clean up the commutator, and the brushes ship as a complete little package it’s very easy to install. I’ve done it on two of my trucks and it’s one of the easiest jobs you can do while also saving you a ton of money and keeping OEM parts on your truck.
    only other thing I would check is the alternator fuse in the fuse box next to the battery, that is the sense line that drives the exciter in the alternator, if that fuse is blown your battery light will be on, but it also means the rectifier or another important part in the alternator may also be broken. You can basically buy all the parts for these alternators individually so it’s worth just replacing the problem part if you have an issue.
    The junk at AutoZone doesn’t hold a candle to the OEM Denso alternators, so it’s worth a few minutes of troubleshooting to do it right.
  14. Sep 23, 2022 at 12:50 PM
    Potomus Pete
    Hippy
    I should have known....Needs new spark plugs and wires. I just replaced them a few years ago. My 24 yr truck has been going thru wires. Every other year they go bad. NGK Blues,plugs $225 Also need a new alternator $400. I also need a new ex manifold that I will do. They wanted $400 for that. I replaced it years ago and will do it again with Dorman
  15. Sep 23, 2022 at 3:26 PM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    Did your mechanic diagnose the battery light as needing new plugs and wires? If so, look for a new mechanic.
    picturethis likes this.
  16. Sep 23, 2022 at 3:53 PM
    Potomus Pete
    Hippy
    If I had an OBDll would it tell me about the wires. Asking about a cheap one
  17. Sep 23, 2022 at 4:01 PM
    Skulking
    San Jose, CA
    An OBDII scanner won't tell you anything about the plug wires. The only way to tell they need to be replaced is if they have obvious signs of physical damage, or if you pull them and check the resistance with a multi meter.
  18. Sep 24, 2022 at 4:16 PM
    Potomus Pete
    Hippy
    Ok...My truck runs smooth again with plugs and wires. Next issue that I have is my idle went from low to stalling to high idle at 1100rpm's with the new stuff. I havnt fooled with it yet, but is there a screw adjustment for idle??
  19. Sep 25, 2022 at 10:36 AM
    kgw
    kgw
    SoCal
    99 PreRunner
    Not really...Check all the vacuum lines that are behind the throttle body, including the pcv line.
  20. Sep 25, 2022 at 10:43 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No, the idle is computer controlled by the idle air control valve. I wonder if they maybe cleaned the throttle body and didn't unhook the battery to reset the idle.
