Battery Light on, Engine Turns off When Merging
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheGibster, May 29, 2012.
  1. May 29, 2012 at 1:41 PM
    TheGibster
    TheGibster [OP] New Member
    Nevada
    2000 Tacoma Prerunner
    How's it going everybody I am a new guy from Nevada! I just bought a 2000 Tacoma Prerunner a little bit ago. So my Battery light indicator is on and the truck runs perfect with calm around town driving. However, I put my foot on it to merge when It shifted to second I had to step on the brakes and it died. It will turn right back over. I got off the freeway and it doesn't do it every single time just randomly. It doesnt sputter it just turns off. I have checked the battery cables, and I took a quick glance at the fuse box and I couldn't see anything blown.
    Thanks
  2. May 29, 2012 at 1:57 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Fuel filter, had a subaru that was fine until you pushed hard on the gas. new filter fixed it.
  3. May 29, 2012 at 2:07 PM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    ^^^ This. I had a GMC Sierra and a Honda Civic that did the same thing. The Civic was just the fuel filter, the Sierra was the fuel pump!
  4. May 29, 2012 at 2:10 PM
    Aw9d
    Aw9d That one guy
    Az
    x2
    My Integra did the same thing, fuel filter was bad and clogged up.
  5. May 29, 2012 at 2:28 PM
    TheGibster
    Nevada
    Sweet Ill check that and post if that fixed it or not. Does anyone know about that battery light? What would cause that?
  6. May 29, 2012 at 2:40 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Voltage is out of operating perimeter. Either the vehicle is off and the key is in the "run" position or the alternator is not functioning properly.
  7. May 29, 2012 at 3:11 PM
    TheGibster
    Nevada
    Ok sweet Ill check that too.
    Thanks for all the info everybody. Ill check all that stuff out and report my findings.
