Battery Light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chevjoe, May 12, 2020.
  1. May 12, 2020 at 12:04 PM
    chevjoe
    chevjoe [OP] Member
    Hi,
    I have a 2014 Tacoma Sport TRD with about 114,000 miles and the battery light came on when I started it up one day and hasn't gone off since, over a week ago and haven't driven it much since. I checked the battery connections, cleaned, looked at the alternator for corrosion on the connections and even traced the battery terminal into the fuse box and everything looks solid.
    I took it to autozone and had them test the battery and alternator and that came back within their specs, they had be rev the car up the 2.5K RPM for some load, I forget the numbers that chatted back to me. I also took a multi meter up to the battery ( which is only about 3 years old) and it registered 12.6, revved it, put the radio, lights, windshield wipers on, seemed good. Last night for an additional test I swapped the battery from my wifes care and stuck it in my truck and started it for a few minutes and the batter light stayed on.
    I can just got out and buy an alternator and install it, probably going to be a pain in the ass how tight things are, but wanted to see if anyone else has any ideas before I do that. I tried to do a search on the forums and didn't really see to much more on this subject other then what I have already stated.
    Any assistance would be appreciated. Thanks
    Joe
  2. May 12, 2020 at 12:08 PM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    12.6 volts is to low if the engine is running it should be in the 14-14.2 range. It will run on the battery but will not charge it.
    wilcam47 and whatstcp like this.
  3. May 12, 2020 at 12:10 PM
    chevjoe
    chevjoe [OP] Member
    Thanks for the quick reply, I could be wrong with my numbers when I started it.. I will double check, I know the battery was in spec when I tested it, and then put my wife's battery in...
  4. May 12, 2020 at 12:27 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    It will be in the 14.x range if the engine is cold. Once fully warmed up it's not at all unusual for it to be at 13.4. These measurements are taken with the engine idling - transmission selector in Park and all accessories off.
    whatstcp likes this.
  5. May 12, 2020 at 12:48 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    battery light means there is a charging system problem - probably time for a new alternator
    wilcam47 and Turdyota3000 like this.
  6. May 12, 2020 at 12:49 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You are running the right tests.
    The battery key off and min is 12.6. Start the Tacoma and at idle check again and voltage should be higher than when off as said above. Increase rpms up to 2000 and turn on AC, blower, access and voltage should not be less than the 12.6 (or what was measured off). If less alternator replacement time - but the auto store should have seen that. Check the main lead on the alternator and the plug in connector also. Been doing any work lately on the front area of the engine- pulleys, belt, hoses, AC work, ps hose? You can also pull the belt off alternator and spin the alternator and listen for grinding and feel for wear or wobble.
  7. May 12, 2020 at 1:27 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    davidstacoma likes this.
  8. May 12, 2020 at 1:46 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Kudos OP for pulling out the multimeter!! in my opinion, that is the best first step.
    Jimmyh likes this.
  9. May 12, 2020 at 1:49 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would have the alternator tested by someone else before you just go out and buy another.
  10. May 12, 2020 at 3:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This may help the charge LED is what you are calling the Battery Light. Since you have ruled out the battery the issue is with the regulator (which is built into the alternator) or the wiring between the alternator and the LED.
    I would vote that the Alternator/Regulator is the most likely culprit.
    I would also go with an OEM alternator over a crappy auto parts store rebuild. Unless you just like replacing them on a regular basis.
  11. May 13, 2020 at 2:38 AM
    muddog321
    FL
    130A Denso from Carid $117. Free core return postage also. Your best option.
    06Tacooo likes this.
  12. May 13, 2020 at 5:44 AM
    chevjoe
    chevjoe [OP] Member
    Thanks for all this information to each of you, I am going to replace the alternator as when I did another battery test all the numbers checked out. I wouldn't mind going OEM but damn they are so expensive, I have always had good results with Bosch, anyone suggest another good brand? I have no intentions about being cheap about but OEM is over priced.
  13. May 13, 2020 at 5:55 AM
    muddog321
    FL
    Denso is OEM. Toyota has no new Denso alternators so they sell you a Denso rebuilt at 3x the Carid price for same alternator.
    Info from Sep 2019 when I looked at alternators for 2005-2013 with tow (130A):
    1. Only Toyota remanufactured replaces all internals such as rectifier and voltage regulator at about $300 plus your core #27060-0P020-84 . New ones are hard to find as no castings made still and #27060-0P020 at $385 and up new but good luck finding one.
    2. AZ has New Duralast Gold at $231.99 lifetime and remanufactured at $163.99 plus core $45 lifetime.
    3. Advance has CARQUEST reman at $163.99 plus 35 core limited lifetime and a Denso reman at $224.11 plus 65 core only 1 year warranty.
    4. NAPA has Bosch reman at $175.99 plus 89 core with 2 year warranty and a Denso reman $203 plus 85 core 1 year.
    5. O'Reillys has Ultimate reman at $167.99 plus 35 core limited lifetime.
    6. Amazon has a ton of who knows ones New but good luck no real names or ratings I saw.
    7. Carid has Denso reman $117.54 plus 79 core 1 year, AC Delco reman $183.71 plus 62 core 2 year, and New AC Delco add a pulley at $300 no core 2 year.
    8. Rock Auto has a bunch, Denso reman $126.99 plus 84 core 1 year #210-0572, the AC Delco reman at $180.79 plus 62 core 2 year #3342691A, New AC Delco at $290.89 no core 2 year #3351302, then a New Remy at $200.79 #94752 and Remy reman at 82.79 plus 60 core #12453 (I have no info on the REMYs quality).
    Jimmyh likes this.
  14. May 13, 2020 at 5:56 AM
    smithlaketaco
    Houston, Al
    I have had good luck with local alternator shops rebuilding the OEM ones. Usually take it to them in the morning and they have it ready that afternoon. 9/10 times it is just the brushes that need replaced.
    Jimmyh and spitdog like this.
  15. May 13, 2020 at 6:03 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I purchased the DENSO 130A reman. alternator from Rockauto, twice, both times they were defective, had to send them back. It really surprised me. Instead I wound up going with a Delco-Remy reman. alternator. Working great now. I'd say 13 years and 400,000 miles on the orig. Denso alternator was a pretty good stretch.
    Skyway likes this.
  16. May 13, 2020 at 6:03 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Did you ever get around 14v on your multimeter with the engine running? If you did the problem isn’t the alternator, and more likely a sensing circuit issue.
  17. May 13, 2020 at 7:10 AM
    chevjoe
    chevjoe [OP] Member
    hmm, I got 13.9, so when you mean sensing circuit, is that built into the alternator possibly?
  18. May 13, 2020 at 1:34 PM
    davidstacoma
    David
    NC
    Not an automotive tech, but looking at the diagram posted earlier it’s likely the M connection at the alternator Going back to the Engine Control module line. I would check all connectors at the alternator and make sure they are secure, and also at the BCM. If not the problem there I’d head to a dealer or a shop that knows Tacoma electrical for diagnostic.
  19. May 13, 2020 at 8:07 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Actually, your best replacement option is Napa. You will pay more but the quality is much better. Do not buy from other parts places (Autozone, Advance, etc.) they are all junk and you will be replacing the alternator quickly.
    Skyway likes this.
  20. May 13, 2020 at 10:00 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Napa is good stuff. Your Battery may have a bad or failing cell inside as well... don't rule that out.
