Battery light still on after replacing battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Samzmurchyk, Sep 27, 2018.
  1. Oct 1, 2018 at 6:31 PM
    GreenYoda
    GreenYoda Well-Known Member
    Could still be a loose wire. Can you have a buddy read the voltage while you drive around. It would be pretty EZ to find +12 and a ground from the cigarette lighter socket. Or just run 2 temporary wires.
  2. Oct 10, 2018 at 4:18 PM
    Samzmurchyk
    Samzmurchyk [OP] Well-Known Member
    Samuel
    2005 white Tacoma TRD 4.0l
    Stock
    Found the problem. Same plug issue but one of the wires was hanging on by one strand. And it was right at the end of the plug so you couldn’t see it. It made the battery read 14.15V but it charged it on and off hence battery light.
    EDDO, devkurf, b_r_o and 1 other person like this.
  3. Oct 10, 2018 at 5:17 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  4. Oct 11, 2018 at 5:03 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Yep...OP - who did you buy the replacement alternator from?
  5. Oct 11, 2018 at 4:09 PM
    GreenYoda
    Glad you found it.
  6. Oct 12, 2018 at 7:10 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This battery light sounds like it actually does not indicate anything about battery life and rather goes on if there is an alternator or charging problem.
    Does anyone know?
    My battery recently died and I had no such light go off prior to the battery failing.
  7. Oct 12, 2018 at 7:23 AM
    Lester Lugnut
    The battery ICON on the dash is misleading. It represents a charging issue.
    Someone who doesn't understand this sees a lit up battery ICON and thinks the battery has a problem.
    If that light stays on very long, they will have a battery problem along with a less than adequate charging system.
    PackCon likes this.
  8. Oct 12, 2018 at 12:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's a "charging system " warning light.
    If the battery voltage gets below a certain point the light turns on.
    If they put a little pic of an alternator on the dash as the warning light, no one would know what it meant
    PackCon likes this.
  9. Oct 12, 2018 at 12:31 PM
    MilSpec
    MilSpec Well-Known Member
    2014 Tacoma TRD Off-Road [1GR-FE] [A750F]
    I would get a proper load tester to rule out a defective battery. I know it is new, but it can happen. Not sure what your trickle charges is capable of, but a multimeter is not the way to test a vehicle battery/charging system. I had a bad OEM battery that showed a solid 12.5V on the multimeter, but would not even take a jump start due to a broken plate/cell. Once the battery is ruled out, you can focus on other areas with more confidence.
  10. Oct 12, 2018 at 1:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check post 22.. he found a frayed wire at the connector
    MilSpec[QUOTED] likes this.
  11. Oct 13, 2018 at 9:29 AM
    MilSpec
    I see... must have missed that
  12. Oct 16, 2018 at 1:54 PM
    GreenYoda
    Lester Logout - I had Chelmsford auto electric rebuild the alternator for me. They have been there a long time and I have used them before but for boat electrical parts. I don't know what was replaced other than the regulator. When I got it back it looked brand new.
    Lester Lugnut likes this.
  13. Oct 16, 2018 at 1:57 PM
    McSwine
    McSwine Well-Known Member
    Levy, Arkansas
    I "rebuilt" a couple of alternators back in the day by simply replacing the brushes.
    b_r_o likes this.
