Battery Mysteriously Died: Turning on Headlights Kills Electrical System After Jump Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2BeersPlease, Oct 4, 2017.
  1. Oct 4, 2017 at 11:44 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I was just going to ask that. Start at the battery.
    I hate electrical gremlins.
  2. Oct 4, 2017 at 11:50 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The engine/computer draws a small amount of current compared to headlights, so it's possible to drive on just battery power for a while with no accessories on. The alternator may only be putting out a small amount of current, enough to keep the battery charged while driving without lights.
    Try measuring voltage at the battery with voltmeter with engine running, then with headlights on.
    2BeersPlease[OP] likes this.
  3. Oct 4, 2017 at 11:50 AM
    2BeersPlease
    2BeersPlease [OP] Well-Known Member
    And the only reason I mentioned getting my oil changed was because when my truck was up on the hoist, the tech unbolted my skid plate and let it crash to the ground. I heard the crash from the waiting room and knew instantly what it was. Because of that, I made them a suspect in this even though they probably had nothing to do with it...probably.
    I guess I'm going to start looking at all the connections now.
  4. Oct 4, 2017 at 11:51 AM
    2BeersPlease
    I'll try that.
  5. Oct 4, 2017 at 11:52 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I would get a multimeter and test the voltage while the truck is running. Then turn the truck off and test the voltage of the battery while it's still connected. Then test the voltage while the battery is disconnected. What this will do is tell you whether you have a parasitic draw somewhere in the system. For example if the battery doesn't drain while it's disconnected from the car, but it drains while it's connected to the terminals, that will indicate a parasitic draw. If it drains while it's on and off the car. Bad battery.
  6. Oct 4, 2017 at 12:06 PM
    2BeersPlease
    Went out to test the battery. The truck started right up. I shut it off and hopped out to go get the multimeter.
    But before doing that, I noticed this USB cup holder thing I have that plugs into the 12v outlet.
    I unplugged it yesterday when I was trying to start the truck. I plugged it in and tried to start the truck again. No go. Unplugged it and still no go. Just makes a click sound.
    Too many variables for my little brain.
  7. Oct 4, 2017 at 12:14 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Start by eliminating possible problems. I'd still have battery checked and check alternator voltage. Or drive to oreilys and have them check alternator output on the vehicle
  8. Oct 4, 2017 at 12:22 PM
    2BeersPlease
    Truck started again. Checked the battery: running was ~14.1, not running was 12.5.
    And it wasn't a click when I tried to start earlier. It's more like a buzzing sound, like a small electric motor is running. It's seems to resolve itself somehow after a short time.
  9. Oct 4, 2017 at 1:03 PM
    mwrohde
    Sugar Hill, GA
    I'm getting a starter vibe. But, I think the starter can't spin until the gear extends out. Maybe the motor you are hearing is the fuel pump?
  10. Oct 4, 2017 at 1:21 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    And what is the voltage with headlights on, engine running and not running?
  11. Oct 4, 2017 at 1:25 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Check for a loose ground while you are at it.
  12. Oct 4, 2017 at 1:38 PM
    2BeersPlease
    Running, it was the same.
    Isn't the fuel pump is in the gas tank?
  13. Oct 4, 2017 at 1:43 PM
    2BeersPlease
    Just checked again with the lights on. Running was about 13.8, not running was 11.98.
  14. Oct 4, 2017 at 1:45 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yes. If theres a electrical sounding whine when you turn the key on thats prob the fuel pump you hear.
  15. Oct 4, 2017 at 1:46 PM
    #35
    wilcam47
    Will
    Bourbon state
    Id get the battery load tested and alternator checked just to be safe.
    98tacoma27 likes this.
  16. Oct 4, 2017 at 1:47 PM
    #36
    ANDROOO
    ANDROOO Well-Known Member
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    do you have any corrosion in your electrical
  17. Oct 4, 2017 at 1:47 PM
    #37
    2BeersPlease
    That's my next move as soon as the guy patching a big hole in my dining room ceiling finishes.
    wilcam47[QUOTED] likes this.
  18. Oct 4, 2017 at 1:53 PM
    #38
    2BeersPlease
    Not that I'm aware of, but I haven't inspected the connections underneath.
  19. Oct 4, 2017 at 1:56 PM
    #39
    mechanicjon
    Jon
    Scottsdale Arizona
    Connections can look clean. The only way to be sure is to take them off the battery post. Just clean them to be sure. Eliminate the unknowns.
  20. Oct 4, 2017 at 2:11 PM
    #40
    ANDROOO
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    My mustang looked clean ended up being the ground wire corroded on the frame connection lol just an idea all your instances mimicked mine
