Battery Mysteriously Died: Turning on Headlights Kills Electrical System After Jump Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2BeersPlease, Oct 4, 2017.
  1. Oct 4, 2017 at 8:05 PM
    #61
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    That'll do it.
  2. Oct 4, 2017 at 8:46 PM
    #62
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Ah, I missed that post. It's called contact resistance and the higher the current the more the voltage will sag from it. Finger tight isn't quite good enough. All mechanical connections have a little resistance, switches, relays, spade and bullet connectors, bolt on terminals too, even the various bolted connections between frame members which are susceptible to corrosion. Glad you found the problem and that it was an easy fix.
    2BeersPlease[OP] likes this.
  3. Oct 5, 2017 at 7:35 AM
    #63
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Even though I don't alway follow this advice myself, I always tell people to check the easy stuff first. I've had my share of bad contact on batteries and starters, corrosion inside battery leads, etc., and didn't alway take the shortest path to fix it.
  4. Oct 5, 2017 at 8:42 AM
    #64
    2BeersPlease
    2BeersPlease [OP] Well-Known Member
    Overlooking the obvious is common for me because I usually think, "Nah. It can't be that. Must be more complicated."
    No issues starting this morning. The last thing I have to do before scheduling the "Meet and Beat" is put my headlight harness back in.
    mechanicjon likes this.
  5. Oct 5, 2017 at 7:15 PM
    #65
    2BeersPlease
    Ok. Hooked the headlight harness back up. No issues. Been starting fine. So I guess this is resolved.
    Thanks everyone for the feedback. I'm a little less ignorant because of it.
    wilcam47 and mechanicjon like this.
