Battery Not Charging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaff33, Nov 1, 2009.
  1. Nov 1, 2009 at 1:05 PM
    shaff33
    shaff33 [OP] Active Member
    Adam
    Harrisburg, PA
    06 Tacoma double cab
    Today I had a few places to run around to, and on my way home, I noticed that the "Battery" light came on. I figured that I would check that out as soon as I got home. However, I then noticed a few mintes later that the "ABS" and "Break" light came on as well. I pulled over and shut of the truck, thinking that if I started it back up, the lights would go off. Well, just the opposite happend. The battery was so weak that the truck wouldnt start. Needless to say, I had it towed to my machanic.
    I am thinking the alternater, but the truck is an 06 and I wouldnt expect that to break already. I am hoping that it isnt anything more serious.
    Did this happen to anyone? Does anyone know what may have happend?
    Thanks!
  2. Nov 1, 2009 at 1:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It could be a fuse. Have all of the fuses checked.
  3. Nov 1, 2009 at 1:07 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Take the battery into autozone or something and have em check it. If the battery is good you'll know its something else...I would hope its not the alternator but who knows...good luck bud
  4. Nov 1, 2009 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Also, its possible the battery connections may be bad....or a poor connection to the battery.
  5. Nov 1, 2009 at 1:11 PM
    ColtsTRD
    Scott
    AZ
    x2 check the cables and make sure there connected securely and make sure theres not a bunch of gunk and shit on em. Getta a wire brush and clean the hell outta the cable tips just for good measure;)
  6. Nov 1, 2009 at 7:47 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Sounds like the alternator went tits up and you were running off battery power to me. You can't go very far on battery power alone.
  7. Nov 1, 2009 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be the #3. thing to check.
  8. Nov 1, 2009 at 7:56 PM
    dexterdog
    Oly WA
    2012 F150
    It can easily be the first thing to check with a multimeter. For the vehicle to all of sudden lose complete voltage to charge the battery and it going dead the first thing I would check would be the alternator.
  9. Nov 1, 2009 at 10:24 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i know amco will check your system for you for free. they also code read for free too... not useful for this forum, but log that in your memory - it'll save you a diagnostic fee someday ;)
  10. Nov 2, 2009 at 4:25 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    You'll need to bring the battery to full charge before they can test it.
    I can't check belt routing right now, but if the alternator is on a separate belt from the water pump, check it too. If it is slipping or broken that could affect charging. (If the same belt drives the water pump, you would overheat before you ran the battery down.)
    Check all battery cable connections (as previously stated) including the big cable to the alternator and chassis ground connection.
    Good luck!
  11. Nov 2, 2009 at 5:16 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Did you do any wheeling? If that alternator get shitty inside it will go up on ya. I had to hose mine out and let it dry before it worked again.
  12. Nov 2, 2009 at 3:43 PM
    shaff33
    Adam
    Harrisburg, PA
    I talked to my mechanic today. He is a family friend who has his own car shop. He said that he has worked up lots of Tacoma's but never had an alternater go out. However, he said that he charged the battery and it held the charge. He was going to drive it home tonight and then back to work tomorrow. He said that when the alternater is running with a load, that then the alternater might start losing power.
    The problem is, he needs to find if/when the alternater is not working before my warranty can be claimed. I just hope this isnt going to be a serious and on-going problem...
    Thanks for everyones advise, I now have some great ideas to check out if this situtaion ever happens again.
  13. Nov 3, 2009 at 12:40 PM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Generally, when something like that happens , you automatically look at the batter terminals, as mentioned above . Make sure they are tight, clean, which really should not be a problem with a 06. Once the mechanic has it, you read the codes. Then check the output of your alternator to spec's, if thats good check the battery.
    You never know about battery's , I saw a guy at Sears drop one off a shelf and he put it back up, you know that had to do some damage to the plates. Stuff happens, including alternators.....
    Let us know what all the tests prove out.
    Jeff 06,V6, SR5, 6spd
  14. Nov 3, 2009 at 1:44 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yep......................altermator.......................ops,alternator:D
  15. Nov 3, 2009 at 4:48 PM
    crutch024
    crutch024 Well-Known Member
    Scott
    Fairfield, Ohio (near Cincinnati)
    2014 Spruce Mica TRD Sport Doublecab
    Pop & Lock 8521; Extra Power Outlets in Center Console; G-Tek Fab Door Sill Protectors; Salex Organizers; NFAB Side Steps; Weather Tech Mats
