Battery or alternator issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by omg_miiiike, Nov 28, 2020.
  1. Nov 30, 2020 at 11:25 AM
    #41
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    I WANT ONE
    Tacman19[QUOTED] likes this.
  2. Nov 30, 2020 at 11:40 AM
    #42
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Something else you can try .. If you have a VOM (And if you don't, even a cheap-o one from Harbor Freight will work) ....
    With everything off ... Check the voltage of the battery. It should be somewhere between 12 - 12.5 volts fully charged. (This is NOT a load test, which should pull a lot of amperage, simulating a starter motor..)
    Once the truck is running, check the voltage at the battery posts and it should read approx. 13.8 volts. That means the charging system is working OK. If nothing changed, you got a prob with the alternator, voltage regulator (which now days is built in the computer) or a wiring problem.
  3. Nov 30, 2020 at 1:51 PM
    #43
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Great call. Take a quick look at the ground like @wrightme43 said. They do these grounds at the factory over new paint so 3 or 4 years it's not going to be any better. A snowflake washer from the hardware store will always help and ensure the ground is metal to metal. When I was with KIA we would do all the grounds with these before we put a electrical part on the car. 13 of them.
    Zim
  4. Dec 1, 2020 at 4:44 AM
    #44
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    +3 for grounding issues. Find, clean to bare metal on both connections, spray wd-40, or similar to keep water out.
  5. Dec 1, 2020 at 9:13 AM
    #45
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I had an issue with a BMW a while back. Started with a radio static and surge. Dead battery one day, charged but would not hold charge overnight. Ended up being a faulty alternator.
    I had to argue that both the radio and the battery failed as "consequential damage" resulting from the alternator.
    Got everything covered under warranty, even the battery due to the failed alternator that killed it.
    shakerhood and wrightme43 like this.
  6. Dec 1, 2020 at 9:35 AM
    #46
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Is this why the directional signals on BMWs never seem to work? ;)
    Chew, Tacman19 and wrightme43 like this.
