battery or alternator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, May 10, 2011.
  1. May 10, 2011 at 6:43 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    so my truck died today. didnt leave the lights on just died while i was in class. got home after someone jumped me and it died again. got it jumped. while i was driving around after i would flip the headlights on and the radio would cut out and then come back on. then i would turn my fog lights on same thing. at one point it almost killed my truck. battery or alternator? on my scangauge it says my battery is running at 13.5 to 14.2 when its on but once it turns off its completely dead
  2. May 10, 2011 at 6:50 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    well im gonna go to autozone and get a battery first cus thats the easiest and cheapest to replace
  3. May 10, 2011 at 6:50 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Check the battery at like a autozone then if it's good check the alternator.
  4. May 10, 2011 at 6:51 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Great minds think alike <3
  5. May 10, 2011 at 6:51 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    okay. im pretty sure its the battery cus it hasnt been replaced in 3 years
  6. May 10, 2011 at 6:52 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    r ur battery post's clean, & r u getting a good connection with ur battery terminals?
  7. May 10, 2011 at 6:53 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Good point. Clean it up with some baking soda and water
  8. May 10, 2011 at 6:53 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    they pretty clean. i mean ive seen worse
  9. May 10, 2011 at 6:54 PM
    smoothguy
    smoothguy Member
    jon
    east ky
    2000 tacoma 4x4 2.4 5 speed
    try the old test take the positive terminal off the batterie while the truck is running if i dies the it's the alternator if it runs then its the batterie.
  10. May 10, 2011 at 6:58 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    black positive red negative right? haha
  11. May 10, 2011 at 7:04 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    nvm red positive black negative
  12. May 10, 2011 at 7:17 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    well i talked to one of my mechanic buddy's and he says it the battery because once the trucks running it says 14.2 volts on my gauge
  13. May 10, 2011 at 8:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    ^^^ Yup. The scangauge is reading voltage output from the alt. Yours being 13.5 to 14.2 is pretty normal.
    Its the Batt.
  14. May 10, 2011 at 8:39 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    fuck. autozone just raped my wallet. 131 dollars on a new battery because they were out of the cheaper ones
  15. May 10, 2011 at 8:44 PM
    LoLux
    LoLux Member
    D.
    South
    09 Tacoma, 2.7 Regular Cab
    100% factory.
    Cant do that anymore, not on modern cars and trucks. It will damage the computer.
    It doesn't seem like the battery has been fully charged. Bring it to the Advance and have them load-test it.
  16. May 10, 2011 at 8:45 PM
    LoLux
    LoLux Member
    D.
    South
    100% factory.
    24 group size or 27?
  17. May 10, 2011 at 8:56 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I've done it to my truck with no problems...
  18. May 10, 2011 at 9:06 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I've seen battery cables so bad with corrosion they swell and break through the insulation, so check that also. But my guess battery
  19. May 10, 2011 at 9:58 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    there was very little battery corrosion around the terminals and i cleaned it off and jumped it again let it run for awhile and then turned it off. same thing wouldnt start. so got a new battery. no problems so far running like normal
  20. May 10, 2011 at 10:39 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    So what kind of battery did you get?
