Battery or normal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, Jan 22, 2011.
  1. Jan 22, 2011 at 10:37 AM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Quick question....I've noticed that sometimes when starting out in first gear (I have a manual) and I lug the engine just a tad, the headlights will dim pretty significantly. I'm wondering if the battery I have is slightly underpowered for the V6. It is a fairly new Interstate Megatron II 550 Cold Cranking Amps / 690 Cranking Amps.
    Reason I ask is when I do the same thing on my daily driver Hyundai 4 cylinder the lights do not dim at all.
    Thanks
  2. Jan 22, 2011 at 10:44 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Normal. Alternator driving electical power and the slower speed of the alternator is causing the light dimming. I had the same thing on my 2000 2.7L.
