Battery question about Northstar 27F battery...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Jun 3, 2019.
  1. Jun 3, 2019 at 5:41 AM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I hear they are very heavy-as should be I guess for the power they make. I also hear that our Tacoma's have issues with the core support area failing. Will going with a beast like the Northstar battery cause long term issues with the battery box area of the rig? Just wondering before I pull the trigger on a new battery.
  2. Jun 3, 2019 at 5:43 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Just got a new 27F myself. Sure it’s heavier than the OEM battery but not by that much. Should you go with a 31, that’s a different story. I’ve got no problem here.
  3. Jun 3, 2019 at 9:28 AM
    Taco'09
    Taco'09 Well-Known Member
    @pearing
    For reference, the 27F, 710 CCA OEM battery (Johnson Controls made) that came with my TRD OR with tow pkg. weighs in at slightly more than 51 lbs.
    I too share the concern about the weak core support so I made an under support from the battery tray down vertically to the frame using some of the rubber bushings salvaged from upper shock mounts and the OEM rubber bushings from the core support (replaced then by urethane ones from Energy Suspension), some 1/2" OD all-thread, large washers and an L-bracket at the frame. Nuts on the all-thread allow me to adjust the support force applied on the bushings to maintain the gaps in the body panels at the LH fender and hood to the same on the RH side.
  4. Jun 3, 2019 at 9:43 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm sure other TW members have even longer experiences with theirs but, FWIW, I've run my Northstar 27F for a couple of years with ZERO problems.
    If you don't need the 27F's 930CCA and 195min RC, the 24F (840CCA and 160min) will save you 11lbs.
    Note that you'll need a voltage booster to properly/fully charge any AGM battery you install.
