battery question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chop, Jul 14, 2014.
  1. Jul 14, 2014 at 5:44 PM
    chop
    chop [OP] Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    Is it possible to have a faulty battery even though the green light on top is still
    on , yes it is a stock battery that 5 years old. the battery was strong till i cleaned the posts and the problem started?
  2. Jul 14, 2014 at 5:58 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes the green light thing is nothing but glitz.
  3. Jul 14, 2014 at 6:38 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    whats the problem?
  4. Jul 14, 2014 at 6:53 PM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    Take it to a battery dealer and let'm test it.
    I would say it's kaputz tho'.
    Needs to be tested.
  5. Jul 14, 2014 at 7:36 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Even if it tests OK I'd just bring it in to a shop and get a new battery installed and your charger/system tested. After five years its due - I'd rather use a new battery now than suffer with the old and then give a later purchased new battery to someone else if /when you sell the vehicle.
  6. Jul 15, 2014 at 6:05 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    next time don't clean the posts with a power sander:D
    seriously; get rid of a battery with 60 months on it; not worth the cost of a future tow....
    This global cooling, esp in alberta, hammers the life out of storage batteries.
  7. Jul 15, 2014 at 6:13 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Byron, the "green light" is actually a mini hydrometer measuring the Specific Gravity (the State of Charge) in one of the six cells in your wet "Maintenance Free" battery. Anyone of the other five cells could be unhealthy causing poor cranking performance or loss of capacity. Loss of water is a very common problem for this battery type, especially in hot climates. Most auto parts or battery stores will test your battery or charging system for free and it only takes a few minutes.
    For more information, please see Section 4.4.3 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  8. Jul 15, 2014 at 6:48 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Yes, what is the problem?
  9. Jul 15, 2014 at 4:12 PM
    chop
    byron
    British Columbia
    problem is it doesn't start , cranks for a second and then clicks . going to replace it .
    What is the best choice out there ?
  10. Jul 15, 2014 at 4:15 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Diehard Platinum if you are looking for something off the shelf
  11. Jul 15, 2014 at 4:31 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    YEP-time for a new battery.
    In the few days prior to my batteries end--you could tell that it was having difficluty "turning over".
    5 years is a long life for a battery-time fo a new one.
  12. Jul 15, 2014 at 7:13 PM
    chop
    byron
    British Columbia
    ya, it has been harder to start lately !
  13. Jul 15, 2014 at 8:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes it can still be bad.
    I'm most likely going back with battery from toyota.
    I'm still on my stock battery with over 7+ years on it.
  14. Jul 16, 2014 at 3:45 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    A weak battery can increase the duration of current on the starter's copper solenoid contacts causing slow clanking and to burn. This is probably the clicking sound you are experiencing. If the battery tests bad, then it should be replaced. If the clicking continues while cranking, there is a good possibility that the starter solenoid contacts are burned and not making a good contact. This is a common starter problem. To a lessor extent, the starter's brushes might be worn to the point that there are not making a good contact. Depending on the temperature, it is all about getting between 200 to 600 amps to the starter motor.
    If you are a DIY'er, starter contact replacement takes about an hour and costs less than $15 in parts.
  15. Jul 19, 2014 at 2:26 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    WELL?? Problem solved??????
  16. Jul 19, 2014 at 2:42 PM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    A load test will show its time to replace.
