Battery recomendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by William H. Bonney, Nov 20, 2022.
  1. Nov 24, 2022 at 10:22 AM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
  2. Nov 24, 2022 at 10:32 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Id suggest checking out the Northstar AGM mentioned earlier, it is not a Marine battery, it is a high performance automotive USA made AGM. The CCA is substantially higher than lead acid (unlike your example), along with reserve capacity, the life is longer than lead acid and it is maintenance free unlike lead acid. How many people actually monitor their battery fluid levels in lead acid and top it off?
  3. Nov 24, 2022 at 10:57 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I check levels every 6 months. I personally found that my truck hardly fluctuates at all, but the deep cycles on my camper needed a minor top off about once a year.
    The AGMs are a quality battery, if one has a need for it. There's a tiny weight penalty compared to flooded cell, and of course they are pricier. But for people who run a heavier load than what the alternator can offset, you're right, they are worth looking into. I honestly never thought of AGM, because they never fit my needs. But I'm not everyone.
    I almost went AGM for the camper. Almost. I was looking into a pair of 6V cart batteries versus an equivalent bank of LiFePO4. The only thing that stopped me from going AGM was the weight: 100 pounds for the pair versus 25 for the lithium. The batteries mount on the trailer tongue. So in that case, it was spend the extra hundred and buy lithium.
    For my truck: I have a number of accessories but I don't power any without the engine turning, and none will overwhelm the recharge. OEM battery is still going strong on a 4 year old truck, and the eventual replacement will probably be another flooded cell. Glass mats are definitely a solid choice for those who need them, but for me the ROI isn't there.
    P8trit likes this.
  4. Nov 24, 2022 at 12:48 PM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    Mine just died just shy of 5 years. Toyota Hawaii, Hilo don’t carry OEM, it’s interstate, which is crap, the dealer here told me it’s all recycled batteries in new covers now…..
    Went with Napa legend, 3yr replace, 5 prorated but should last longer and was cheaper than interstate from dealer 1yr replace.
  5. Nov 24, 2022 at 2:57 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    :anonymous::hattip:
  6. Nov 24, 2022 at 5:49 PM
    William H. Bonney
    William H. Bonney [OP] Well-Known Member
    2016 TRDOR
    I ended up getting the AAA battery, with a AAA discount, finding a 25 dollar visa gift card and the core deposit…it came to 183 bucks.
    RyanDCLB and Steves104x4 like this.
  7. Nov 24, 2022 at 6:03 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Another vote here for NAPA Legend…have had great luck with them for years.
  8. Nov 25, 2022 at 7:06 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Twice a year for vehicles and OPE.
    At my work I had many deep cycle batteries, they were checked/topped up every 2 or 4 weeks depending on application. With only a few minutes care per month the batteries had long service lives.
    shakerhood and P8trit like this.
  9. Nov 25, 2022 at 7:23 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Excellent choice. After have them, i'd not buy any other.
    RustyGreen and Delta09[QUOTED] like this.
  10. Nov 25, 2022 at 9:16 AM
    Tcodyw88
    Tcodyw88 Well-Known Member
    Cody
    El Segundo, Ca.
    2020 TRD offroad
    The factory battery out of my 2020 started leaking and caused corrosion on my terminals. But it was from rock crawling and being vertical so now I’m looking for a battery that won’t leak.
  11. Nov 25, 2022 at 9:24 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I have used AutoZone or Advance branded AGM's in 2 trucks now. They are all made by Johnson Controls, but cheaper then a Northstar, etc and you can get one, or get a replacement, in nearly every town in the US.
    I got a 24F (stock size) but it provides a bump on all the categories. I run a winch, a WeBoost on a 3a circuit, and a 15a circuit that can run my fridge and recharge my Jackery at the same time. Have not had any issues.
  12. Nov 25, 2022 at 9:24 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Most batteries are made by a handful of manufacturers in North America. They just build to spec and slap on customers label. My suggestion is get the cheapest with the best warranty. I also suggest AGM which usually has higher amperage and cold crank. Also less corrosion on terminals and no liquid to spill.
  13. Nov 25, 2022 at 9:25 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Costco battery if the best deal. Price, return policy, and warranty.
    AZ Pete likes this.
  14. Nov 25, 2022 at 3:44 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'd go with the best warranty! Costco and Walmart gets my vote!
    Those fancy, more expensive ones do not last any longer, nor give you better value.
    TexasWhiteIce and AZ Pete like this.
  15. Nov 25, 2022 at 8:11 PM
    #35
    ILuvHotTaco
    ILuvHotTaco Well-Known Member
    2017 TRD OR DCSB MGM
  16. Nov 25, 2022 at 9:57 PM
    #36
    duckytw
    duckytw Well-Known Member
    Antigravity lithium battery. Pricey but it does crank the engine like a strongman starting a lawnmower
  17. Nov 26, 2022 at 6:03 AM
    #37
    zoo truck
    None
    I don't even screw around anymore choosing what battery to buy after having many different names over the years. Just go with a deka and be done with it. My last 2 were good for 10 years. Last one was still in the truck at 10 years when i sold it.
    J Williams likes this.
