Battery reliability POLL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bshammer0, Jan 1, 2018.
have you had to get your battery replaced under warranty?
  1. Yes
    35 vote(s)
    17.6%
  2. No
    154 vote(s)
    77.4%
  3. Replaced myself
    10 vote(s)
    5.0%
  1. Jan 8, 2018 at 7:28 AM
    #41
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    mine died a couple of month shy of 2 years, had corrosion and everything! called 5 dealership to try and get it replaced under warranty but they said i am over the 25K miles on the truck!!!!! got an 890 Amp interstate battery from Costco to be honest i was chocked that they put a 582 amp battery in there seems kind of low for the size of truck! my co-worker tried to jump start my truck with his new corolla and failed miserably he had a 320 Amp battery in his :I
    2016Tacoman, CusterFan and shakerhood like this.
  2. Jan 8, 2018 at 7:33 AM
    #42
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    I had a big 800cca agm battery that was only 2 years old in my old dodge. The second i put my winch on, I swapped that battery into my toyota
  3. Jan 8, 2018 at 8:49 AM
    #43
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    For anyone in the market, this is the battery I replaced it with:
    https://www.batteriesplus.com/productdetails/sli24fagmdp
    Right now, $30 mail-in rebate AND you can get 10% off if you order online then go to a Batteries + Bulbs (used to be batteries plus). So, for $240 + tax you can replace w/ a badass deep cycle battery that has a 60 month replacement warranty and 840CCAs
    16tacoblue and shakerhood like this.
  4. Jan 8, 2018 at 9:00 AM
    #44
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    MTP-27F Interstate Battery is the one they should of put in your truck. It is a 6 year battery, 710 cold cranking amps.
    https://www.interstatebatteries.com/product-search-results
    sxe4533[QUOTED] likes this.
  5. Jan 8, 2018 at 9:10 AM
    #45
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are the stock Tacoma battery "Maintenance Free"...mine does not say "Maintenance Free" on it. The manual does not say check the water level. Is this because we are idiots and they don't want us to get near the battery?
    bshammer0[OP] likes this.
  6. Jan 8, 2018 at 9:15 AM
    #46
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The caps come off for you to check and fill if needed, the old Tacoma Batteries used to have the glass eye in them which was pretty cool.
  7. Jan 8, 2018 at 3:02 PM
    #47
    GoFightNguyen
    GoFightNguyen Member
    2017 TRD Sport
    Just finishing up at the dealership now. It took 3 hours of diagnosing and troubleshooting and coffee drinking before they decided its a bad battery and needs to be replaced. Super. That's what you want in a 2017 TRD.
  8. Jan 9, 2018 at 6:51 AM
    #48
    snefo
    snefo Well-Known Member
    Right at 2 years and 26k miles. Volts okay but no current. Load tested bad. Jumped it and drove to dealer. Replaced under warranty. Never had a battery fail that fast.
  9. Jan 9, 2018 at 7:48 AM
    #49
    bshammer0
    Brandon
    Nashville, TN
    Same here - though I didn't let mine fail, it was only a short matter of time before I was stranded or needed to jump on a freezing winter's night. that thing was leaking all over the place with tons of corrosion - more corrosion than I had on my 6 year old battery in my old Rav4. I got about 8 years out of that stock battery before it bit the dust... Now that I've bit the bullet, I'm OK with it - at least now I know I have a solid battery in there that will last even if it did come out of my pocket!
    shakerhood likes this.
  10. Jan 9, 2018 at 6:00 PM
    #50
    Dale98c5
    Dale98c5 New Member
    Dale
    2016 White Tacoma
    18 months,40k miles dead battery. Dealership replaced under warranty after a little bitching.
    bshammer0[OP] and shakerhood like this.
  11. Jan 18, 2018 at 5:53 PM
    #51
    mr_ash
    mr_ash Well-Known Member
    Ash
    Colorful Colorado
    2016 DCSB TRD OR
    Mine just died...18 months. Dealership measured something like 225 CCA instead of the expected/rated 580 something CCA, so they replaced under warranty.
    Buys me a little more time to save for an OGE dual-battery setup :thumbsup:
  12. Jan 18, 2018 at 5:56 PM
    #52
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I’m on my 3rd battery under warranty in 11 months
  13. Jan 18, 2018 at 5:59 PM
    #53
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Battery died in <1 year
  14. Jan 19, 2018 at 2:52 AM
    #54
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Next month will be the 1 year mark -- so far so good. Will do a load test just to see where things are.
  15. Jan 19, 2018 at 3:46 AM
    #55
    16tacoblue
    16tacoblue Well-Known Member
    2016 sport taco
    Colored chrome fenders name plates & tailgate emblem flat black.
    still have the oem one in.14 months still checks good ,made it thru winter so far but am getting low battery warning on key fob...:rofl:
    good to have good info on replacement,may just replace soon as it warms up don't need any surprise...
  16. Jan 19, 2018 at 4:06 AM
    #56
    JRMiller
    JRMiller Well-Known Member
    James
    2017 Tacoma TRD Off Road
    I'm on my fourth Tacoma, the last two trucks 2010 and 2014 both batteries failed exactly at the three year mark, no warning whatsoever, got in and no click, DOA
  17. Jan 19, 2018 at 5:26 AM
    #57
    IPNPULZ
    going to be fun!
    My 1st battery was @ around 9.67 volts Battery two was @ 10.81 volts when they died. Battery three seems to be holding firm even through the cold here...
  18. Jan 19, 2018 at 5:48 AM
    #58
    OkieCowboy
    OkieCowboy Well-Known Member
    Lloyd
    Choctaw, Oklahoma
    2012 TRD 4X4 Access Cab
    2017 TRD built in June. So far so good.
    Another battery story: I bought a new 2000 Crown Victoria for the school district I worked for. We started watching the original Motorcraft battery about 2010. Only a couple of us drove the car. We decided to carry a new battery and socket wrench to see how long the battery would last. Periodically we would change out the extra battery for a new one. I pulled the Vic in the garage before Winter Break, 2014. It gave up with final clicks in January, 2015. 155,000 miles. I have retired but that Crown Vic is used nearly every day and is on its third battery.
